Burning oil
Old Mar 21, 2012 | 11:50 AM
str8t six's Avatar
just use 5w-20 like the manual says with a motorcraft filter.
Old Mar 21, 2012 | 11:59 AM
jbrew's Avatar
That's way to simple...
Old Mar 21, 2012 | 12:12 PM
MGDfan's Avatar
I prefer 'borked'
Old Mar 21, 2012 | 12:18 PM
jbrew's Avatar
Originally Posted by MGDfan
I prefer 'borked'
Right "Chaotic" , -that creative instinct.
Old Mar 21, 2012 | 12:58 PM
str8t six's Avatar
i guess for some people it is.
I prefer 'borked'
Old Mar 21, 2012 | 01:56 PM
1997 lariat 4.6's Avatar
I prefer 'borked'
still too simple! as dad and i put it, "well what the F**k?!"
Old Mar 21, 2012 | 04:09 PM
code58's Avatar
Originally Posted by Tan_F150
I know the owners manual calls for 6qts.but 6qts doesn't put it to the top.I called 3 different dealerships.2 told me 7qts and 1 told me 6qts.So I figured i'd put 6.5qts in it..
Listen to the ones who told you 6 qts. (on an '01), ignore the ones who said 7 qts. because they don't know what they're talking about. 6 qts. WHEREVER that puts you on the stick IS FULL! Many, many vehicles currently have a "range", not a "low" and "full" like they used to. Anywhere in that "range is perfectly OK. DON'T fill it to the "top" mark, that is most often overfull, not good! I have owned 6 new vehicles in the last 12 years (cars and trucks) and NONE of them have had a "low" and "full" stamped on the stick, only a range. 3V 5.4L take 7 qts., but NOT your truck, ONLY 6 qts. (NOT 6&1/2 or 6&3/4, ONLY 6!)
Old Mar 22, 2012 | 02:47 AM
jbrew's Avatar
Well, I sure hope he gets it now. If not - That's all I got to say.
Old Mar 22, 2012 | 03:50 AM
code58's Avatar
Old Aug 13, 2021 | 02:15 PM
safari801's Avatar
Was that dipstick measure before or after you ran it? You need to run the engine to check for leaks and fill the filter and after doing that for a few minutes then check your stick. In fact if there's no leaks drive it for a couple miles and then check the stick.
Old Aug 13, 2021 | 04:12 PM
Thread is 9 years old........
