Oil Filters
Old Sep 2, 1999 | 07:54 AM
wisman's Avatar
Question Oil Filters
Has anyone done a comparison of the new style oil filter for the triton motors & the old standard Fl-1A?
Aside from the obvious length difference and price difference, I can't see why a person couldn't use the old style if he had the space. I'm going to do the 1st filter change this week & will cut it apart for an internal look-see. BTW, Ford's responce to my question was "your owners manual says the part # for your vehicle is blah, blah, blah....
99 SuperDuty-XLT,4x4,5.4/5speed,410gears,StdCab,8'Box,UDblack/Grey,GTSomniGuardSE,UltraBoards,MoonVisor,LEER100x l,SonyCD
Old Sep 2, 1999 | 09:49 AM
Tenderpaw's Avatar
Post
I bet the threads are different on the new filter. Remember, the FL1A has been around since the fifties and was based on the English system of measurment. I'm sure the new filter is a metric measurement and is sized differently. Even a slight difference could be enought to ruin your engine. Don't take a chance. The filters have got to be different or they would have the same part #.
4D THNDR's Avatar
Exclamation
I use Frams so if you are refering to the one that used to fit (Fram's PH-8A) nearly every Ford made in the past the nipple size is different.
Red 99.5 Lightning,#0975,Born 5/6/99...Adopted 5/27/99 SuperChip
Old Sep 2, 1999 | 11:42 AM
Henry Ellal's Avatar
Post
have a question. has anyone used Hasting oil filters? comments would be appreciated.
Thanks, Henry
99 F-150 XL 4x4. RC Flareside 4.6 5spd, 3.55LS. gibson 3" cat-back, K&N Gen ll.Westin step bars.Ventshade window deflectors and bug deflector and a cool white shifter ball. The SILVER BULLET. Rock and Roll...Baby!!!
Old Sep 2, 1999 | 06:57 PM
mkrieger's Avatar
Question
Wisman,
What is the number of this new style filter?
I thought most all Fords used FL1A, FL820, or FL400S. All three of these filters are different. The 1A and the 820 are the same diameter, but are of differnt lengths, have different end plates and different mounting threads. The 400 of course is long and thin. For more oil filter info check out this link. http://minimopar.simplenet.com/oilfilterstudy.html
Michael Krieger
99f150@pickupman.com
mkrieger@mailcity.com
99 F-150 XLT Supercab, 4x2, Bright Red/Harvest Gold, 4.2L, Automatic, 3.55LS, 255/70R16 Goodyears, Captains Chairs, Keyless Entry, CD Changer, Tow Package
Accessories: SuperChip, Donnelly Compass Mirror, Lariat Wheelwell Moldings and Bumper Cap, Ford Splash Guards, Bug Shield, Bed Mat, WeatherTech Deflectors, Mobil1 Synthetic Oil
Modifications: Painted Tailgate Handle, A/C on/off switch
Old Sep 2, 1999 | 07:43 PM
4D THNDR's Avatar
Lightbulb
He's refering to the FL-820
Red 99.5 Lightning,#0975,Born 5/6/99...Adopted 5/27/99 Chipped w/SuperChip Flipchip chip, Mobil 1
Old Sep 3, 1999 | 02:05 PM
TSSCS's Avatar
Post
Hello all...is it possible to change the oil on late model F-150 w/out taking the truck to a shop? I have a 95' Bronco and I have been used to changing the oil myself. Is the filter easily accessible? I just ordered a Y2K F-150 and was wondering if i'll have to take it to the shop. By the way, what do you all think of synthetic motor oils?
Old Sep 3, 1999 | 04:25 PM
Dunbarton's Avatar
Post
TSSCS,
If you are getting a 4x2 it's "a piece of cake." Drain plug and filter are next to each other and "right there!"
A 4x4 is a little tougher but certainly not that difficult since the filter is placed out of the way of the transfer case.
Many of us use synthetic oil, many don't. There are a lot here that have many miles on our engines using petroleum based and synthetic oil, both old and new trucks. Whatever you feel comfortable with and if you don't mind the extra cost of synthetics.
More important is the "3 month/3000 mile" oil changes with filter done on time, all the time.....
Dunbarton "The Middle Aged Kid" '99 XLT SC SB 4x2 4.6 auto 3.55 ls The occasional Z-71 Eater! Wedgewood & Denim, SuperChipped, Airaid FIPK, Rhino Liner, leaky rear slider. Man, I got it all!
Old Sep 3, 1999 | 06:11 PM
JA_Stang86's Avatar
Post
wiseman, the oil filter on the new F-Series incorporates an anti-drainback valve (I think it is part of the filter). I do not believe the FL-1A has this feature in it. I would not substitute filters (my opinion).
Jeff
1999 F150 Lariat
Reg cab Short box Styleside
5.4L 3.55ls
Deep Wedgwood Blue/Silver
Lund Interceptor hood shield, VentVisors, Class III hitch, Ford molded mud guards, soft tonneau, factory CD with changer (thanks Dusty), tinted windows
http://www.fortunecity.com/silversto...ton54home.html
Old Sep 3, 1999 | 08:42 PM
4D THNDR's Avatar
Exclamation
The filter on my '98 F150 S/C 5.4 4X4 was located in the bumper on the drivers side. Could have kissed the engineer that put it there. Easy as hell to access. Before anyone says anything about it getting damaged in an accident lemme tell ya what I told my brother when he complained about that, "If you hit something hard enough to damage the filter you probably really should stop the vehicle, duh!"
Old Sep 8, 1999 | 12:25 AM
wisman's Avatar
Lightbulb
Mute Point!
The threads on the nipple ARE different. My error for not mic'ing them earlier. The old FL-1A will NOT fit the triton motors.
Thanks to all for the comments.
Old Aug 28, 2006 | 10:06 PM
metallitera's Avatar
the FL1A and the FL400S are the same threads (3/4-16), and both have an ADB valve. the FL1A is bigger, and the valve is nitrile whereas the FL400S' is silicone.
when i do my dual filter setup, im gonna use FL1As
Old Aug 29, 2006 | 03:17 PM
GIJoeCam's Avatar
IIRC, the 820's seal diameter is a little bit dofferent than the 1A/400 as well. The 1A and 400 were essentially interchangable. Many people with 400s (e.g. Escorts) would switch over to the 1As when they were on sale. It cost an extra half quart of oil to fill the system, but the extra capacity doesn't hurt anything.
I wonder if there is a difference in the media's filtration rating?
-Joe
