Need help asap!
Old Mar 4, 2012 | 10:55 AM
What makes you think you need a new PCV?
Old Mar 4, 2012 | 11:08 AM
jethat's Avatar
Motorcraft PCV only. order it from Rock auto.
Old Mar 4, 2012 | 01:28 PM
DTB1's Avatar
Originally Posted by leopold
How about the FPDM since you say it is worse when it is damp or snowing? Just a thing to look at and if it has never been replaced wouldn't hurt to do it .
Are u talking about fuel pressure driver module?
Old Mar 5, 2012 | 06:35 AM
JCR 56's Avatar
The 03 doesn't have a fuel pump driver module.
Old Mar 8, 2012 | 10:05 PM
DTB1's Avatar
i went and put a bottle of Techron in my tank and im still getting po174 and po171 checked hoses for leaks nothing. I change plugs motorcraft. i dont know what to do next ?
Old Mar 8, 2012 | 10:07 PM
DTB1's Avatar
The power is just not there.
Old Mar 8, 2012 | 10:47 PM
K.R.newbie's Avatar
try going back to basics. are you sure you have spark at the spark plug!!!! do you have gas getting to the spark plug??? try cranking it with out any electric and see if spark plugs r wet after???? if the code indicates lean then gas is the issue. hope you get it figured out.
P.S check the fuel pressure.
Old Mar 8, 2012 | 11:16 PM
DTB1's Avatar
i just change the plugs they were white. what about fuel pressure regulator? dont see gas coming out of it are there any other ways to check it?
Old Mar 9, 2012 | 01:09 AM
jethat's Avatar
Rent a fuel pressure gauge and check the fuel pressure.
Old Mar 9, 2012 | 07:44 PM
DTB1's Avatar
K I went. Out and got a fuel pressure tester it reads 36 when turn key. 32 when its running and when I pull the hose off fuel pressure regulator it reads 40 to 41 psi I know 32 is low what could it be?
Old Mar 9, 2012 | 08:29 PM
jethat's Avatar
You have changed the fuel filter recently?
Old Mar 9, 2012 | 08:48 PM
DTB1's Avatar
Yea two times
Old Mar 9, 2012 | 08:53 PM
jethat's Avatar
pump or regulator. I've never done diagnostic I would probably just replace the pump. Never replaced a regulator myself. Could be the problem though. Maybe someone will chime in with the diagnostic steps..
Old Mar 9, 2012 | 08:55 PM
jethat's Avatar
just re read your original post. Its gotta be regulator seeing how you replaced..
Old Mar 9, 2012 | 08:59 PM
jethat's Avatar
rock auto has the motorcraft regulator for 45 bucks.. looks like a fairly easy part to install..
