Heated O2 Sensor Circuit Malfunction, Error Code P0156
Old Aug 30, 1999 | 07:49 PM
ace's Avatar
ace
Post Heated O2 Sensor Circuit Malfunction, Error Code P0156
I read an error code from my truck computer. The following error code was displayed, P0156 Heated O2 Sensor Circuit Malfunction (Bank 2, Sensor 2) I reset the check engine light. I am sure it will come on again after I do some highway driving. Does anyone have any suggestions how to go about fixing this problem without shelling out the big $$$ to have Ford fix it.
Thanks....
Old Aug 30, 1999 | 10:49 PM
Bill_Aquino's Avatar
Post
It's probably one of the oxygen sensors, there are 4. Two are ahead of the catalytic converters, 2 are aft of them. Not sure exactly which one the code points too, but it is probably one of the ones behind the converters. If you clear the code and swap the two aft sensors, you should be able to verify this by the new error code that will be generated. The sensors are relatively easy to change, and are worth about $60 each, and they are available over the internet.
Old Aug 31, 1999 | 12:01 AM
Squanto804's Avatar
Post
PO156 is the downstream(past the cat. towards the rear) Bank 2 which is left side (drivers side). Mine recently showed code PO141 so I purchased a sensor through Ford($75) And it took care of the problem(mine was downstream, bank 1). I asked Ford if they could check the sensor which was in hand and they told me that it had to be in the truck and would cost about $80 to check it. I don't know if this was to pull the code or if they would actually check the sensor itself? If your thinking of buying a sensor you might want to check out www.carparts.com, they have sensors by Bosch for Ford trucks for about $40. Don't know if this helps you or not but good luck.
97 F-150 Black, 4x4 XLT ext.cab,sb,offroad pack.
4" Susp. lift, 3" body
4.56 gears w/LS,Borla exhaust
35" BFG.,16.5x9.75 Weld Scorpio V wheels, Edelbrock IAS Shocks,Lift Lips,
K&N Filter, TransGo Shift kit,
Bug shield,Tinted windows
Sony ES head unit,Sony ES changer,MTX Thunderform sub,Boston Acoustic Proseries up front, Polk in rear,PPI & Coustic Amps,Alpine Alarm
[This message has been edited by Squanto804 (edited 08-31-1999).]
Old Sep 3, 2009 | 10:00 PM
GTME85's Avatar
What method do you use to easily change the sensors. I have the tool, prelubed the threads, and ran engine to warm things up.Any other ideas?
Old Sep 4, 2009 | 01:48 AM
ONELOWF's Avatar
Wow! A ten year old thread.
Old Dec 6, 2009 | 11:57 PM
Redline_cdn's Avatar
I just got this code on my F150 and all I can say is "love that search function"
cause I didn't know which bank was which and was thinking bank 2 was
the passenger side until I searched the forums.
10 yrs old or not, I got my answer.
Thanks F150online
Old Dec 7, 2009 | 06:03 AM
jbrew's Avatar
Another One ? Holey Crap Man... Yea, someone or some thing has released Bugfarky toxins into the frickin air. Somethins goin on..
