Can sum 1 please ID these parts for me.
Number 2 I believe is the inlet for the cold climate system that ties into the pcv elbow and throttle body. It has a hard line that wraps around the pcv valve then goes to the back of the throttle body at that elbow you see. What plenum is that?
Anyway, the hose that connects to that ends @ the heater core hard line. This hose is often referred to as the bypass hose.
BTW- I've never seen a PCV elbow like that in the past. Actually that looks like it has a coolant wrap around integrated. So that may eliminate the need for a plenum tree.
Like I said, all that can be plugged off if you live in a warm area, above freezing most of the time.
