jerking misfire at low rpm
Old 12-06-2011, 11:39 PM
blk450er's Avatar
At 100k I was experiencing a hard jerking that I though felt like the tranny slipping in low rpms under load especially towing. A few people suggested that I change my plugs cause I hadn't did that at the time. I changed them and the problem completely went away. Now almost 20k later its doing the same exactly thing again. I never changed the coil packs and didn't know if that could also be something to consider since I know its not my tranny?? It's an 04 5.4
Old 12-07-2011, 12:07 AM
What brand spark plugs did you use?
Old 12-07-2011, 12:54 PM
blk450er's Avatar
Oem
Old 12-07-2011, 12:58 PM
azmidget91's Avatar
Any codes?
Old 12-07-2011, 01:11 PM
jethat's Avatar
One or more of your 8 coils has failed. You dont have coil packs. if you have a cel get the code read and it will tell you what cylinder(s)
Old 12-07-2011, 07:14 PM
blk450er's Avatar
No check engine light and I looked up the codes on my gryphon anyways,no codes at all.....how much are the coils to replace, just to see if that's what it is as a check
Old 12-07-2011, 07:23 PM
jethat's Avatar
E-bay has them. Search DG-508. The more you pay the better the quality may be..
Old 12-07-2011, 10:39 PM
blk450er's Avatar
Should I just stick to motorcraft or is there any better coils??
Old 12-08-2011, 01:23 AM
glc is offline
The 04 5.4 uses DG-511, not DG-508.
Old 12-08-2011, 06:32 PM
F1X540's Avatar
Don't buy off of ebay...Get good ones...I had the Globals and had nothing but problems.
I bought Borg Warners, and no problems..
Old 12-08-2011, 07:10 PM
jethat's Avatar
thats right.
Old 12-08-2011, 08:49 PM
blk450er's Avatar
Do the coils sound like the issue since its doing the same thing as the plugs?
Old 12-08-2011, 08:50 PM
blk450er's Avatar
What about motorcraft, isn't that Oem??
Old 12-08-2011, 11:48 PM
jethat's Avatar
yes motorcraft are OEM and if you can afford them they are probably the best. you can get them at rock auto at a discount.
Old 12-09-2011, 12:21 AM
Justin_w32's Avatar
Had the same issue it threw a code I replaced #6 coil with a Borg Warner, still had the same problem took it to my mechanic said #5 was bad too replaced it with another Borg Warner, turns out that one was bad out of the box. Didn't know what the problem was so I took it back and they replaced the "new" bad #5 coil and plug....Fyi you may want to just buy some extra just in case. I probably would of came out cheaper just buying a set of 8 from the start.
I was pulling my hair out trying to figure out what was going on. I didn't expect that a brand new coil would be defective. Hope you get it all back in working order.
Quick Reply: jerking misfire at low rpm
