05 engine removal info needed
Old Nov 26, 2011 | 09:06 PM
THUMPER 01's Avatar
I may need to pull my5.4, 3v motor for a rebuild. The motor hydrolocked due to the infomus stuck open fuel injector. Talked to Ford and checked the build date. Yes, it is covered under the exstended warantee program. I build engines and may want to rebuild this myself. Ive read the manuel on pulling the engine. It dosent mention what a real PIA it might be. Some machanics have mentioned having to lift the cab. Can anybody give me some input on pulling the engine. I may decide to hand it over to the dealer and let ford cover what they should. I have no idea if the local Ford mechanics have a clue. Handing my Truck over to the dealer, to me, is like gambling. I dont gamble. Any input on pulling the engine would be great. Any input on dealing with a dealer on the warrantee program would also help. I dont want to get into a problem with a dealer as they hold my truck hostage. By the way, I worked at a dealership for two years. They have no hart.
Old Nov 26, 2011 | 09:12 PM
jethat's Avatar
I would let Ford do it just because its free.. Pulling the engine shouldnt be that much different then my truck and the deal is you remove the intake then it can be done with the cab in place. Let ford do it. See if you can get them to replace it with an 08+ engine that has the redesigned heads and the cam phaser fixes..
Old Nov 26, 2011 | 09:25 PM
THUMPER 01's Avatar
Thanks for the 08+ tip. From what ive learned, Ford has a central rebuild shop that does all there engins. Its an aftermarket suplier. Ford had to be out of there mind not to recall these engines. There also out of there mind NOT to replace ALL the injectors as part of the exstended warrantee program.
Old Nov 26, 2011 | 10:15 PM
jgger's Avatar
If you do it yourself then you can also count on replacing the cats on your nickle. Rich motors kill cats and it should be included in the work.
Let them do the work, pay for the balance of the new injectors, and just bird dog them while they do the work.
Suck up to the service manager and ask if you can check on the progress as they work on your truck.
Old Nov 26, 2011 | 10:24 PM
THUMPER 01's Avatar
I like your thinking. You are right about the cats. The codes are saying the o2 and canister are effected also. The service manager is about to have a new best friend. Wonder what his vices are?
Old Nov 26, 2011 | 10:34 PM
jgger's Avatar
If you have a good dealer close to you that really helps. I have 2 that are close, one I wouldn't even change my blinker fluid, the other one is top notch.
Good luck.
Old Nov 26, 2011 | 10:58 PM
THUMPER 01's Avatar
Any idea how to check a dealers service departments reputation? This has to be the dummest question I have ever asked. Like I said befor, Its gambling.
Old Nov 26, 2011 | 11:41 PM
jethat's Avatar
Google is your friend. Google them and see what comes up..
Old Nov 26, 2011 | 11:43 PM
jgger's Avatar
Not sure, but if you tell us where you're at I'm sure people will chime in. Both good and bad.
Old Nov 26, 2011 | 11:53 PM
THUMPER 01's Avatar
Hartford, Connecticut. The truck has to be towed in. Anybody deal with Interstate Trucks or Morande Ford??? Thanks for the help.
Old Nov 27, 2011 | 12:12 AM
jgger's Avatar
I guess Frits Ford out here in Calif won't do you any good then.
Old Nov 27, 2011 | 12:15 AM
THUMPER 01's Avatar
Thats a long tow.
Old Nov 28, 2011 | 06:11 PM
DYNOTECH's Avatar
Not sure how far Taska is from you but they are as good as it gets.
