5.4 pulley squeak
When the belt is removed, spin each pulley by hand. Could just be a light squeak you are looking for which at higher rpms becomes louder. I would check the alternator, Idler and tensioner. Is the belt new? Check for signs on the back side of the belt for misalignment. And last, but not least.... and probably most expensive would be the ac pulley/clutches.
Let it run for a minute without the belt on , if the sound is not there it has to be a
front end component,water pump, fan clutch. You have already eliminated the
tensioner and idler. Sure its not the a\c?
