Engine Swap
Engine Swap
Hi I would like to ask for some help with an engine swap.I would like to know if I could swap my 2002 F150 Supercrew 4.6 with a 2007 Lincoln Navigator 5.4 3valve it comes with the wire harness and the computer any help would be greatly appreciated Thank you very much!..........KW
You'd be better off doing this>>> https://www.f150online.com/forums/ar...ght=swap+notes
It will be a lot less headaches
Engine Swap
Thanks for the info guys!....The only reason im considering this motor,is bcuz of price and its local.....07 Navi 5.4 W/41,000 miles $750 obo with the harness &computer.it was rear ended and its been sitting since he aslo said he would throw in anything else i might need anyways once again thanks for your help
it would be worth paying more for a 2v. More reliable engine albeit less powerful and it would be about 10 times easier to convert to a 5.4 2v. There was one guy here who did the 3v conversion. He posted lots of info on it and it really looked the PITA.. power steering needs custom work Throttle body stff like that. Top it all off with the known issues the 3v engine has.. Cam phasers going out plugs getting stuck in the heads and all. The 2v is a more reliable engine.
once you read about the issues involved in the 2 valve to 3 valve swap you'll see the error of your ideas
Thanks for all of your advice,I ended up getting a 4.6 out of a 97 Expedition with 70,000 miles on it its a Windsor just like mine.I got it from a guy and his Dad real nice gentleman he gave me the motor for $100 he was super cool and was defiantly not hurting for money so I took his word that the motor is good,I should be able to just swap it out with the old motor correct?....should I go threw the hassle of changing the PI heads from the old motor?Thanks for your help I really appreciate it!
