serious problems???
Old Dec 1, 2011 | 09:47 PM
Gotts2BMe's Avatar
stop over thinking it.
You have a coolant leak that is leaking out all your antifreeze. Fix or replace your rad. The white smoke is condensation build up in the exhaust. Until it gets heated up enough to burn it off it is just water vapour.
Old Dec 6, 2011 | 10:49 PM
monsterjeep's Avatar
it starts right up every time no problem it drives fine it is showing a lean code check engine. also having trouble finding hydrocarbon tester. and how would i tell if injectors are leaking and what to look for when remove.
Old Dec 6, 2011 | 10:51 PM
anti freeze level never moves i cant tell that it has dropped the white smoke that comes out smells really rich tho would that be condensation build up?
Old Dec 6, 2011 | 11:17 PM
jethat's Avatar
it is most likely normal condensation.
