Knock sensor codes
Old Sep 22, 2011 | 04:16 PM
redfx4rod1's Avatar
Knock sensor codes
My 04 F-150 has always had a knocking sound wich they told me it was a lifter but I have never had problems with it. Just last week the engine started to loose power at some point while it was driving and when taking off I pressed on the gas to try to get it to go and the check engine came on I took it to get checked and it said knock sensor 1 and 2 malfunction. How can I know if the knock sensors are no good. Also do they need to have ground or can I move them from the block somewere else.
Old Sep 22, 2011 | 05:31 PM
kevhead75's Avatar
Post the actual pxxxx codes. I doubt both sensors would fail at the same time. I don't believe they are easy to get to either.
Old Sep 22, 2011 | 06:19 PM
It's more likely the knocking sound is the VCT and the knock sensor failure is coincidental. If it's spark knock, it should go away with premium gas.
Old Sep 23, 2011 | 12:13 PM
redfx4rod1's Avatar
Will take it back to get checkd and ill post codes later.
