Seized alternator - Help!
Hey boys, any tips on freeing up a seized alternator? Vehicle sat for a few weeks and I think the moisture got to it. Can't get a socket or wrench on the pulley bolt due to lack of clearance, and when I crank the engine, the belt slips.
Who's got the magic?
An alternator is not that hard to remove on these engines. Pull it off and check it out. I suspect the only magic you will find is at an auto parts store in the form of a reman. Make sure the belt and belt tensioner are in good shape as well. good luck.
Thanks for the help guys. I was able to get some WD-40 into the guts of the alternator by use of a 1/4 inch tube, and then managed to get a socket on the pulley bolt and put some leverage on it. Got it freed up and the engine started and did the rest.
Thanks again.
Thanks again.
