Something short the lines to injectors
Old Sep 11, 2011 | 03:22 PM
venxxxxx's Avatar
2000 F150 4.6L V8 with the driver's side fuel injectors not working. The whole rail with 4 injectors showed no NOID lights, but the spark plugs still spitting sparks.
I checked all wires for continuity from ECU plug to injector plug, they were good.
What could be wrong ?
Old Sep 12, 2011 | 08:03 AM
Electron-Jack's Avatar
If it's only one side I would suspect the ECU has an issue especially if you already confirmed continuity on that side. You should check for continuity from ECU to injector connector which you did already and also confirm there is no continuity from the injector connector to GND on the positive signal pin. Just because you have continuity from ECU to injector connector doesn't mean that you don't also have a short to GND in the cable but it would be a really odd way for it to fail on all 4 injectors at the same time.
Old Sep 19, 2011 | 12:02 PM
venxxxxx's Avatar
I was thinking its the ECU as well.... im saving up to get one, hopefully by the end of the month if not then early October. I will update on its status.
Old Sep 19, 2011 | 12:17 PM
you can have good continuity and still have a short to ground. check for resistance from the power pin to ground to test for a short to ground
Check near the bulk connector just above the drivers frame rail, split open the loom, and check for any chaffed wires.
Old Oct 8, 2011 | 11:37 AM
venxxxxx's Avatar
No, I was right all along. It sure was the brain of the truck. The ECU has shorted out on one of the chips that controls the fuel injectors on the driver's bank.
I paid $199 for the ECU programmed from autoecuexchange.com and another $85 for the locksmith to reprogram the keys and the beast woke up from its 8months sleep.
I towed some 400 miles on it already and still running strong, but it has service lights of P141 and some O2 sensor being hot.
Old Oct 8, 2011 | 12:11 PM
P0141 is the rear sensor on the passenger side - heater circuit malfunction. The sensor is bad or you have a wiring issue. Is there another code?
Old Oct 8, 2011 | 01:13 PM
jbrew's Avatar
edit
Old Oct 13, 2011 | 10:12 AM
venxxxxx's Avatar
now its throwing code P1401 and P0135
Old Oct 13, 2011 | 10:29 AM
P1401 is the dpfe sensor......the most dependable replacement is found at the dealer...
The throttle body, IAC, and egr should be cleaned also......
Old Oct 14, 2011 | 03:47 AM
P0135 is the front O2 sensor on the passenger side, heater circuit malfunction.
Old Oct 14, 2011 | 02:04 PM
jbrew's Avatar
P1401 Diag -
edit
__________________________________________________ ___________
Also -
deleted
Old Oct 14, 2011 | 02:08 PM
jbrew's Avatar
P0135 Slow Response, Sensor, Bank 2
deleted
Old Oct 14, 2011 | 02:38 PM
jbrew's Avatar
From Ford Service -
deleted
