Help my only ride is in bad shape?
Old Sep 9, 2011 | 09:36 AM
  #31
brettb's Avatar
hope thats the case ? going to change it today anyway as I dont want a Fram filter in there
Old Sep 9, 2011 | 03:16 PM
  #32
Still waiting on the plug brand.........................
Old Sep 12, 2011 | 07:51 PM
  #33
brettb's Avatar
plugs say platinum on the receipt? no brand.. I guess I could pull one to figure that out?
today I pulled the throttle body off cleaned it..main chameber it was pretty nasty the shop only cleaned the upper 1/2??? while I had it off I put my Rousch air intake on... cleaned the MAF yet again and replaced the camshaft position sensor since I had one!
Started her up and ran a series of tests for codes...and nothing but heavy rough idle .
took it for a drive ran it up to 65 (in a 35) with heavy throttle pretty rough off idle and thru 1st gear! and at stop sign feels like it wants to die? idle when warm at a hair over 500RPM! got back and still didnt pull codes? so whats up????
Old Sep 12, 2011 | 11:39 PM
  #34
How about CALLING the guy that changed the plugs and asking what brand was used?
Why are you putting an aftermarket intake on an engine that's not running right?
Old Sep 13, 2011 | 02:18 PM
  #35
brettb's Avatar
I've had the intake for nearly 4 months now.. at this point figured it could'nt hurt any? besides i had the throttle body removed.... and it was easier to replace Cam sensor...
actually came out ok for the most part... after a 12 mile test run last night I'm only getting a P0306 misfire in #6 and PO316 random misfire? coasting still good, downshift to pass good...really bad shake at idle and off idle... feather gas pedal after coasting on highway really bad shaking... after about 10 miles got flashing CEL and on the way home the CEL was solid! got home and pulled those 2 codes?????
Old Sep 13, 2011 | 02:57 PM
  #36
Does the new intake leave the MAF in the same position?
Old Sep 13, 2011 | 04:25 PM
  #37
brettb's Avatar
I would say so? pretty close anyways?
maybe a little closer to the throttle body intake port?
Old Sep 13, 2011 | 05:16 PM
  #38
Are you running a custom tune that incorporates that CAI being on the engine? If not, with the 2004, you could be running very lean. Also, if the MAF is not in the same position, it may not read the airflow correctly. I would be very hesitant to put a CAI on a 2004 in the first place and with your existing problems, I sure wouldn't.
Old Sep 13, 2011 | 06:05 PM
  #39
brettb's Avatar
I've heard about lean conditions in f150's .. why do the aftermarket BBK throttle bodies not require a tune then? nor do the instructions for the CAL tell you to get a tune for your F150?
do you think that living at 8,500 ft would starve my truck like it does my motorcycle? most people on this site and other sites talk about being able to break tires loose??? never been able to do that... dont really need to either... but seems like my motorcycle... I take it to 3000 feet and she's a hole new bike! anyways not sure how long my 83 Eagle will last being my daily driver? was beginning to think its more fuel related? how difficult is it to replace the injectors? Haynes manual is not overly specific for the non-mechanic like myself???
Old Sep 13, 2011 | 10:08 PM
  #40
brettb's Avatar
hey anyone know what the plastic device behind the brake res is ? about 11 o'clock standing in front of the truck... sounds like a hiss of air? may be what its supposed to sound like??? but could be vaccum leak??? thanks
think I figured it out... EVAP Canister Purge Valve? should this be making a sound like a tire blowing air out a nail hole?
Old Sep 14, 2011 | 12:09 PM
  #41
kevhead75's Avatar
Nope. Those quick connect fittings on the evap hoses have o-rings in them. Possible that is were it is leaking from. That will definitely cause issues though. They may have removed one to gain access when doing the plugs. I would check and make sure it connected securely.
Old Sep 14, 2011 | 12:57 PM
  #42
brettb's Avatar
the top hose has some play laterally... my big problem is working in the dark as i work 16 hour days...get to work in dark drive.... home in dark work on truck in dark!!!!
I'm likely a vampire! drove it to work today have to run trash so will try to look at it in daylight?
Old Sep 14, 2011 | 01:25 PM
  #43
kevhead75's Avatar
Take a look and listen for the leak. Sometimes those quick connectors don't want to latch right or wasn't very secure when they did your plug change. I would imagine you would be getting a code for it though, maybe lean codes or evap codes.
Old Sep 14, 2011 | 01:52 PM
  #44
brettb's Avatar
The manifold hose is loose on both ends.. the one that goes into the purge valve and the the one the enters the manifold on the passengers side! I cant seem to get either clamp undone??? the only codes I'm throwing now are
P0305, P0306, P0316, P0300
Old Sep 15, 2011 | 06:21 PM
  #45
brettb's Avatar
Sparkplugs are Autolite Revolution HT1: Replaced those 2 with Motocrafts! no change!
#5 cylinder plug was 1/2 black and 1/2 tan the #6 cylinder plug was solid black!!!
remember just barely 1,000 miles on these autolites....
pulled all injectors afterwards and they are looking pretty nasty... was going to order remanufacted OEM with a warranty same as new ones for $35 each?? Good or bad idea?
any other ideas are very welcome at this point? oh and I cant figure out how to release the fuel inline spring compression connector... my haynes says refer to section 4 but I'm in section 4?????
