Chk Engine Light
Old Oct 3, 2011 | 04:04 AM
  #46
Agent47's Avatar
He does have a scanner but it only goes up to a 99. He does have access to a newer one but that is someone elses'es.
Old Oct 3, 2011 | 10:42 AM
  #47
jbrew's Avatar
Originally Posted by Agent47
jbrew, could u please be a little more specific on what needs to be done as I am not really sure what parts need to be done to what. Do u think this is going to cure it?
Hell I don't know anymore. It says yours is an 05 4.6L. Your totally in the wrong forum.
Thing is,- Ford changed the V8's Throttle Body as of 2004. So your 05 has a different system all together. The "Drive By Wire", -motorized TB set up and if I recall, you don't have an IAC on that model.
So some of the posts and links are going to confuse the hell out you. Since they pretty much don't apply.
I might ask to delete this entire thread and start over, -if it were me. Either start fresh in the 2004 + forum or the engine forum. Up to you.
You don't have to uknow, if you have an understanding.
Just an idear..
Old Oct 3, 2011 | 11:35 AM
  #48
Sounds like his doesn't do CAN bus - you can buy a simple handheld that does for 30 bucks. What kind of mechanic doesn't have simple up to date test equipment?
Ask a mod to move this thread to the V8 or 2004-2008 forum.
Old Oct 3, 2011 | 02:23 PM
  #49
Agent47's Avatar
It's still showing a PO401 code.
Old Oct 3, 2011 | 02:30 PM
  #50
http://repairpal.com/OBD-II-Code-P0401-Ford
Old Oct 3, 2011 | 04:11 PM
  #51
Agent47's Avatar
Check Engine Light
I have an 05 XLT 4.6 V8 that has a chk engine light on. I went to Autozone & had it plugged in & it gave a code of P0401. My mechanic eventually took off the egr valve cleaned it out & reset the computer. The following day withing 2 mins of driving it came back on. Today I went back to Autozone & had it scanned again same code P0401. Any ideas? THat code is very generic & covers a multitude of "sins" so how can I find out what the problem really is?
Old Oct 3, 2011 | 04:20 PM
  #52
Did the mechanic check to see if the egr diaphragm passed a vacuum leak down?
Also it could be the dpfe .....those should only be bought at the dealer.....
Old Oct 3, 2011 | 04:34 PM
  #53
Agent47's Avatar
no he did not
Old Oct 4, 2011 | 10:54 AM
  #54
jbrew's Avatar
I have to see what's on the 05 V8. Ah crap, I'll pull it up -
____________________________________________
Yea, I'd pull the plenum and clean the EGR ports. That won't cost you anything and there's a good chance that's the problem.
If not. - It's the DPFE sensor.
Old Oct 5, 2011 | 10:49 AM
  #55
JackandJanet's Avatar
All right everyone. I've merged the two threads and attempted to clean up the comments about posting in the wrong forum. If I didn't get it right, let me know.
Let's try to concentrate on the solution to the problem though.
- Jack
Old Oct 5, 2011 | 10:51 AM
  #56
My head is spinning!
Old Oct 5, 2011 | 11:02 AM
  #57
jbrew's Avatar
Who's not concentrating on the problem ?
Well, whatever, it got a little confusing. Should be good now.
Old Oct 5, 2011 | 03:44 PM
  #58
Agent47's Avatar
Sounds like a plan, thanks!! So is it fair to say that the plenum is the issue then?
Old Oct 5, 2011 | 04:19 PM
  #59
It MIGHT be. If not, it's probably the DPFE.
Old Oct 5, 2011 | 04:32 PM
  #60
jbrew's Avatar
I would go for the ports first. All it will cost is a gasket (9L437). That's a compression gasket. You can try re-using the old one if you choose, I don't , not that one anyway.
_______________________________________________
Your EGR valve is different on top, - not sure what that's all about. (?) If you decide to clean that in any way, be very careful of the diaphragm inside the saucer. No compressed air or chemicals can contact. Max vacuum is 16 hg's and it won't take much more than that.
If you want to perform a running DPFE Multi-Meter test. I made a vid of it's proper operation upon acceleration, here -
https://picasaweb.google.com/1002891...07882591006386
