Engine swap 4.6 to 5.4
Yes it will go in. Read this Any info you need will be in it.
https://www.f150online.com/forums/ar...wap-notes.html
Iam in the processof doing this swap. The one problem I am having is that the t/q bolts are hitting the spacer plate when the bellhousing and blockare mated up. I'm considering washers on the t/q bolts but still visualize them occupying the same space in relation to the block and housing coming together. Maybe two spacer plates? Because it only needs 16th of an inch. Torque converter is fully rotated inward. Has anyone encountered this problem?
