Engine not starting
Old Aug 23, 2011 | 03:45 PM
cnuce's Avatar
Engine not starting
Ok brand new to this thread but not as a mech.
My father-in-law has a F150 with the triton v8 that has a starting issue. It will start and run fine but when you drive it got to point b and shut the engine off it will not start.
If he waits for a hour or so it will start right up and he can drive it home.
He has put new injectors, plugs, fuel filter, and ful pump in it. I haven't had time to look at it.
Any suggestions
Old Aug 23, 2011 | 03:53 PM
Year and engine size?????
Checked for any dtc codes?
If so what are the numbers?
Old Aug 23, 2011 | 08:20 PM
sam1947's Avatar
Your crystal ball is busted too I see......LOL
Old Aug 23, 2011 | 08:26 PM
srfd44's Avatar
sounds like a fuel pump again. You or someone needs to check fuel pressure next time it will not start.
Old Aug 23, 2011 | 08:39 PM
jethat's Avatar
Turns over, but will not start? Fuel pressure test? that's where I'd start just to rule it out..
Old Aug 23, 2011 | 11:53 PM
Yep.....
