08 f150 overheated and ac went out
Old Aug 23, 2011 | 01:43 AM
jose_bigred's Avatar
Well the other day I was driving and my truck overheated while i had the ac on blast. so I pulled over and my efans weren't working. Fixed the problem and now the ac only blows hot air, not a bit of cold air ever since it overheated while I had it on. So if any one could help? I'm clue less in this department.
Old Aug 23, 2011 | 03:46 AM
code58's Avatar
Jose- with the engine running, turn the A/C on and get out and see if the A/C clutch is turning. If not, you need to look in your owners manual (mine is different because it's an '04) and check any fuses and relays that are in the A/C system. Probably just blew the clutch fuse. There may be 1 more fuse in the system as well as a relay.
Old Aug 24, 2011 | 09:16 AM
Ok sounds good I didn't know it was connected to the fuse box but I will check it out and will let you know what happens! Thanks
