expedition swap to f150
Old Aug 22, 2011 | 07:55 AM
archangel2003's Avatar
a buddy had a 2000 eddie bauer edition expedition with the 2v 5.4 engine and 4r100tranny really cheap. and ive got a 2003 f150 with a dying 4.6 and 4r70w. would the expedition parts swap easily with my truck?
Old Aug 22, 2011 | 09:48 AM
Veteran: Army
it's gonna be a PAIN, but if you've got the complete donor truck then have at it
Old Aug 22, 2011 | 11:44 AM
jethat's Avatar
Swapping engines wouldn't be that hard, really. The Tranny's on the other hand would be. You would have to swap wiring, computers, drive shafts would have to be custom made most likely. I wouldn't go to a lower year unless it was really low miles and all.
Old Aug 22, 2011 | 12:22 PM
i plan on having the engine and tranny rebuilt before they go in the truck.
Old Aug 22, 2011 | 02:42 PM
Veteran: Army
then don't mess with the 4r100, have your 4r70 replaced with a built 4r75
Old Aug 22, 2011 | 03:49 PM
would it be that much cheaper to just get mine built?
Old Aug 22, 2011 | 05:06 PM
Veteran: Army
YES, talk to Darrin Burch
Old Aug 23, 2011 | 08:41 PM
ok getting the excursion mid october and rebuilding the engine with my dad. looking to build the engine to get me 350-400 rwhp. any suggestions for my 5.4?
Old Aug 26, 2011 | 12:47 PM
Veteran: Army
yes
Forged rods
higher compression pistons
better cams (probably not super aggressive racing cams but ones intended for truck use)
24# injectors
long tube headers
ported heads
rock solid tune
Old Aug 26, 2011 | 02:29 PM
WORLDBOOK's Avatar
Find you a good machine shop you can trust block prep is very important when rebuilding a modular engine cylinder wall bore and piston clearence can make a difference from a great overhaul and a waste of time read your manuals and piston to wall clearence and have bore checked before doing anything to the engine remember you are dealing with a small bore and the cylinder wall clearence has to be held down or you will have lower engine noise. Make sure the machine shop has done these engine before had a high end race shop cost me thousands because they had never done no more than basic work on this kind of engine,when you push for HP they have to be right and the shop can't just take a guess like they did with me. And on the second go round thing aren't what they could have been, so get it right the first time just wanted to share my exspereince with you so you don't suffer my disappointment. Keep Your Head Up ! WORLDBOOK
