praising the 4.6 2v
Old Nov 10, 2011 | 12:09 AM
archangel2003's Avatar
I'm about to hit 193xxx and no engine or tranny problems yet on my 4.6. Just with it had more power.
I've replaced just about everything else on the truck it seems
Old Nov 10, 2011 | 12:15 AM
Need4racin's Avatar
coobie, how much oil do you burn?
Old Nov 10, 2011 | 08:21 AM
4.6 Punisher's Avatar
I've only got 52K on my 281, but it still runs tip top.
Old Nov 10, 2011 | 11:05 AM
coobies5's Avatar
it varies, but i change my oil (motorcraft 5w-20 6qts and fl820s filter) every 3k miles and sometimes i'll get a little bit over 3qts, sometimes right under 3qts.
it is very obvious i'm burning oil, because at a red light if i'm waiting a good while, when i take off you can visibly see the white/blue smoke shoot out of the tail pipe.
Old Nov 10, 2011 | 11:22 AM
sounds like valve seals are leaking
Old Nov 10, 2011 | 11:36 AM
coobies5's Avatar
along with a slowly dying engine hahahahaha. i'm just going to run it til it gives up for good, hopefully by then i'll have a built engine waiting to go in.
Old Nov 10, 2011 | 11:39 AM
if you're burning oil, you should keep it topped off until you're due for the oil change, no need to make it worse then it is
Old Nov 10, 2011 | 11:51 AM
coobies5's Avatar
i'll just be wasting money....
i change my oil at least 1-2 times a month. however, if work is slow or i'm going somewhere far from home, i'll top it off just to be safe.
Old Nov 10, 2011 | 06:35 PM
shifty_85's Avatar
i loose about a QT ever 3,000-4,000 motorcraft 10W30 or W40.
mine makes a little bit of noise in park but ive noticed alot of tritions do when you put it in gear it goes away.
Old Nov 10, 2011 | 07:32 PM
jbrew's Avatar
Yea, they tend to do that when you use the wrong oil.
Old Nov 10, 2011 | 11:17 PM
shifty_85's Avatar
well with the 5W20 i was burning 2 qts of oil between changes. so i went to the thicker stuff.
my 94 4.6L 2V said 10W40 on it. so why does my 97 4.6L 2V say 5W20???
Old Nov 10, 2011 | 11:59 PM
jbrew's Avatar
Hey, go for it....
Old Nov 11, 2011 | 12:05 AM
shifty_85's Avatar
been doing it for a while.
why would it be bad to have thicker oil??
Old Nov 11, 2011 | 12:11 AM
jbrew's Avatar
Because everything doesn't get lubed. Your hearing noises correct ?
There yuh go.
I'd follow the manual, unless you know better. (?) Maybe you do.(?) Regardless, it's your truck. Do what you think is right.
Old Nov 11, 2011 | 12:18 AM
shifty_85's Avatar
with the 5W20 the noise was twice as loud. every triton motor ive ever heard at idle in park the 4.6L the 5.4L and the 6.8L all make a slight knock at idle in park. been told because its free bearing? or somthing. but the second you put it in gear it goes away.
