Swap a '98 4.6 for a '92 351 Windsor?
Old Jul 26, 2011 | 09:46 AM
Tac Gunner's Avatar
Ok so I have 98 extended cab short bed, 4x4 automatic with the 4.6. The power sucks and I am wanting to build the motor and put a 5.0 stroker with cam, heads, etc. After pricing what it would cost I realized it was shade to much. My dad has a '92 351 Windsor motor sitting on the shelf he said we would put in it providing it would bolt to my bellhousing. My question is whether or not it bolt up. Any help is appreciated.
Old Jul 26, 2011 | 10:42 AM
jethat's Avatar
Not a practical swap. The bells are different along with so many other things. It can be don but its really so much easier to either find a good 4.6 or swap to a 5.4
Old Jul 26, 2011 | 09:34 PM
Veteran: Army
do a 5.4 swap and add a supercharger
Old Jul 26, 2011 | 11:23 PM
twinskrewd's Avatar
^^^^X2! Also the older motor in the truck would cause it to fail emissions test. Don't know if that would be an issue but its worth mentioning.
Old Jul 26, 2011 | 11:43 PM
Tac Gunner's Avatar
Thanks for mentioning the emissions test twinskred but that isn't a concern. I understand what all is involved with switching the motors but I'm trying to find out how different the bolt patterns are. I've have read else where that a 4.2 tranny would bolt to the 351, does anybody know if that is true?. I really don't want a 5.4 as a know people that have had em and have had several problems with the coils on the spark plugs goin out.
Old Jul 27, 2011 | 05:57 AM
Bluegrass's Avatar
You would put up with all the hassle and cost just because you think a 5.4 might present a few issues?
Better re-think that one.
Good luck.
Old Jul 27, 2011 | 09:02 AM
Tac Gunner's Avatar
Well if it makes a difference the 351 will be carbureted and we are going to run the tranny via a stand alone computer. Don't know if you all have priced what it cost to build a 4.6 or 5.4 into a high performance motor but I have priced it for my 4.6 and its ab 9k. That's with trick flow heads, Comp Cams cams, 5.0 stroker kit, MSD system, BBK headers, and JLT intake. That isn't including the cost of having the block machined and trued and having the tranny rebuilt and a new torque converter. In all you are close to 10k, I'm pretty sure I can put the 351 in it cheaper. I do understand that you would prolly have to modify the motor mounts but that isn't a biggy for my dad and I or any other fabrication that would have to be done.
Old Jul 27, 2011 | 10:59 AM
Bluegrass's Avatar
YES TAC is does make a difference.
Why didn't you say that before this and stop waisting other peoples time with a misleading request.
Go ahead and do it.
Use the earlier trans so there is no boltup issue. The 4.2 is too weak to use for such and advanture
You know you have to fab all the rest up anyways.
Good luck.
Old Jul 27, 2011 | 01:53 PM
Tac Gunner's Avatar
Sorry guys, didn't mean to cause confusion. I didn't think about it until I got to seeing everyone flip out about it and then it hit me you all were thinking of a 351 that was fuel injected. So then a 4.2 tranny is to weak even if I have it rebuilt and put stronger internals in it?
Old Jul 31, 2011 | 04:40 PM
Veteran: Army
I wouldn't even waste the time or energy on a carb'd 351, when you can build a faster 5.4 for less $$$$$$$$$$$
Old Aug 2, 2011 | 12:28 AM
jbrew's Avatar
Maybe he confused 351 lightning specs... With the 330 Lightning specs..
Old Aug 2, 2011 | 05:28 AM
phil6608's Avatar
Old Aug 2, 2011 | 02:55 PM
Tac Gunner's Avatar
OK tarajerame, would you please tell me how I can build a 5.4 for less money because I have yet to find good quality parts at a reasonable price compared to a 351W. Especially when I have a 351W already and would have to buy a 5.4
Old Aug 2, 2011 | 04:36 PM
phil6608's Avatar
You have to keep your eyes open!
This one just ended today,(reserve not met) I'm sure he will re-list it.
Only thing it doesn't have is a stroker crank.
But you can make up for that by throwing more boost to it.
He wanted $6150 for it.
http://cgi.ebay.com/ebaymotors/ws/eB...NA%3AUS%3A1123
Old Aug 2, 2011 | 05:04 PM
five0merc's Avatar
There are lightning engines and trannys with all the wiring and computers on ebay and cragislist all the time for around 3500.
