Rough Idle & Surge 2004 5.4
Old Jul 30, 2011 | 07:47 AM
jbrew's Avatar
Originally Posted by F1X540
I have an engine vibration at 1100 and 1900 RPMS. Can feel it in steering wheel. It's NOT an out of balance wheel.
The more load on engine the worse. Like going up a hill in overdrive..
Dealer checked everything. PCM, vaccum, etc. and could not find a problem.
No codes. It is annoying the hell out of me. Other than the RPMs I mentioned ,it runs smooth. Although the idle is a little rough. I cleaned Throttle body, and MAF, with no change..It is a 2004 F150 5.4 engine.
Never had this problem before..
Any ideas would be appreciated...
Thanks..
Under normal acceleration and @ about 45 mph, -right after the shift into OD; is it at that particular load when she's at her worst. She like thro's a sissy fit and yuh feel like brooming her. Yea, right after OD under normal acceleration. Am I making sense ?? Not ? Then disregard and good luck with it.
Old Jul 30, 2011 | 01:58 PM
Scooterdog's Avatar
My Guesses
Check the U-Joints and center bearing. IF they are bad, you'll need a whole new drive shaft. Replace the drive shaft with one from a 2007 or newer, They have replaceable U-joints.
I have also had a tire that balanced perfectly fine (but unknown to even the tire pros) had bad cords. The truck was taken back to the tire store 4 times for balancing with the same vibration problem as certain speeds. once they move the front tires to the rear, I could still feel the problem, but it move from the steering wheel to the back seat.
My first choice is still the U-Joints.
Old Jul 31, 2011 | 03:19 AM
jbrew's Avatar
Instruct the dealer to check Mode 6 data ( cylinder history). If he's clueless, -ask them to stress test the coils. I doubt it's the u joints unless you seriously abuse your vehicle. Everyone I know w/your model year still run their zirk-less original joints. I pulled a car hauler four years back to back. I went thru brakes for awhile, but still run the factory original U-Joints @ 274,000 miles.
I believe you have a low grade misfire. It's not serious enough to cause your engine harm , -via programmed parameters. But it will definitely cheese you off, you'll most likely loose a few hairs in the process.
You can either head to a GOOD dealership and direct them accordingly, - as instructed above. Or, roll the dice and purchase a new set of coils and replace them all yourself.
Good Luck. Common problem, - No Fun.
Old Sep 28, 2011 | 04:56 PM
F1X540's Avatar
Ready to hang myself!
Try to make this short.
2004 FX4 5.4..
Had tapping in engine. Took to dealer#1. Dealer replaced some lifters, slack adjusters, (one was seized) Cam, timing chain etc.. Got rid of tapping.
Now have engine vibrations at 1100 and 1900 rpms in higher gears.
1100rpms is the worst. While crusing at 1100 rpms I have vibration, can feel in steering wheel. If going up hill in overdrive and at 1100 rpms it gets worse the more lugging on engine. Dealer #2 did comp check on engine and tranny.
All good. This all happened after dealer # 1 did the engine work listed above.
Dealer #2 wants to call Ford to see if they know what it is. If Ford comes up with nothing, they are going to put sensors all around engine etc and drive it to see where vibration is. Does anybody have any idea as to why I have this engine vibration after dealer#1 replaced the parts mentioned?
Did the mechanic#1 something up?
Thanks..
Appreciate any ideas the mechanic should know...
Old Sep 28, 2011 | 05:00 PM
F1X540's Avatar
I forgot.
If I leave off throttle when viberating ,the vibration stops instantly..
Old Sep 28, 2011 | 05:41 PM
It might just need new spark plugs and one or more coils.
Old Sep 28, 2011 | 06:28 PM
VAXB's Avatar
May I ask why you didn't take it back to dealer #1 that did the work? they would be the most familiar with what was done. But, to answer your question. My first guess would be its a coincidence and as glc stated it probably just needs plugs or a coil.
If the
Old Sep 29, 2011 | 09:16 AM
F1X540's Avatar
They replaced plugs and coils..Dealer #1 did check it and said it's ok
Old Sep 29, 2011 | 09:46 AM
jbrew's Avatar
Check it again. The coils shorting under load, = low grade misfire.
One of the new coils are bad. Happens all the time..
Old Sep 29, 2011 | 09:52 PM
F1X540's Avatar
But would'nt the comp check pick that up?
It runs fine other than what I said.
Old Sep 29, 2011 | 10:02 PM
jbrew's Avatar
If they were looking for it. They would have to mode 6 for cylinder history, since it only happens at a certain load.
Old Sep 29, 2011 | 10:21 PM
F1X540's Avatar
I know the 1st dealer did mode 6..And probably the 2nd dealer..I feel so lost! I love my truck but can't deal with this crap! Come on! An engine is an engine!..It's like the dealers are trying to figure out a freaking space ship.! Wouldn't you think some body would say.."Hell I know what's causing it" The guy says he has to call Ford.
For what? Isn't he trained to figure this **** out? One minute it runs fine. Mechanic ****s with engine and next it's a freaking horror ride..!!
I'm sorry, but this really pisses me off!
Old Sep 29, 2011 | 10:29 PM
F1X540's Avatar
When I take it back to Dealer #2, On Monday, I'm seriously going to tell them "I do not want truck back until it's fixed"! They agreed to give me a loner..Matter of fact, there motto is "We will fix your auto promptly, and done right" Well prove it....
Old Sep 29, 2011 | 10:33 PM
F1X540's Avatar
Do you think I should take it back to #1 dealer who did the orignal work and ****ed it up ,and say fix it or else..Maybe a lawyer? Or is that pushing it?
Old Sep 29, 2011 | 10:53 PM
jbrew's Avatar
Well iduno. Probably better off to leave it where it's at or whomever you feel that is more familiar with YOUR problems. It's a judgment call. Who are you comfortable with? Have you spoke with the techs yourself?
The techs job isn't always easy, specially with a 3 valve. Having someone else work on it can be good if your receiving really poor service. Other than that, it may work against you.
__________________________
So, do they confirm the problem ? They road test to repeat your concern ?
