Computer not testing EVAP system
Old Jun 13, 2011 | 10:30 PM
chuck gibson's Avatar
Hey Folks,
After repairing my truck and clearing the codes, the EVAP system light is still flashing on an OBD II tester showing that the trucks computer has not tested it. I have drove the truck over 200 miles and it has cooled down and driven until it hit operating temperature at least 5 times putting the 200 miles on it. What could cause it to not test out? The truck has not thrown any more codes.
Any suggestions would be appreciated.
Chuck
Old Jun 13, 2011 | 10:37 PM
jgger's Avatar
IIRC the EVAP is one of the pickiest to reset. It must have all the conditions in order for it to run the test. The amount of fuel, temp, drive cycles, it's just touchy. Might take as many as 10 or 20 drive cycles if conditions aren't met.
There are some smart guys on here (I aint one of them) that might be able to tell you how to speed things up.
Good luck.
jbrew's Avatar
Suggestions for what ? Why do you need that monitor to run ? This isn't a fault.
Did you get a CEL ? If so post DTC.
Old Jun 13, 2011 | 10:40 PM
jgger's Avatar
Probably getting a Monitor not ready on the code reader, but that's a guess.
Old Jun 13, 2011 | 10:45 PM
jbrew's Avatar
Yea, it didn't run yet because conditions haven't been met. Doesn't need to unless your getting smoged in the near future.
If that's the case -
http://www.obdii.com/drivecycleford.html
Old Jun 13, 2011 | 11:00 PM
Yep, That is the case. Texas inspection time at the end of this month. If it does not clear itself withen the next week or so, I will use this procedure.
Thank you much!
Chuck
Old Jun 14, 2011 | 07:30 AM
projectSHO89's Avatar
Check your Texas requirements. Most states allow one or two incomplete monitors and will still pass the OBDII-based emissions testing.
In the meantime, keep the tank between 1/4 and 3/4 full and drive it normally.
Old Jun 14, 2011 | 05:44 PM
Bingo! It passed. The folks told me that in Texas, vehicles using OBD II testing followed this formula:
?- 2000 allows two incomplete monitors;
2001 and after allows 1;
Thank you!
Chuck
