2004 F150 Timing Chain
I have a 04 !50 with a 4.6L in it the timing chain guide on the drivers side shredded and ended up in the oil pan. I took it all apart and cleaned the oil pan and pick-up, then replaced the iol pump while I was there. I put it all back together and now it idles rough. I can unplug one of the plugs and it changes nothing on some of them and some of them it does change the idle of the motor.
I replaced all the timing stuff, gears, chains and such, with a complete set I ordered. When I line up the timing marks on the chain and cam gears the passenger side was at 11 o clock and the drivers side was at 12 o clock. The timing mark on the crank gear was set to 6 o clock. as the Haynes manual stated it should be. Now the truck when idling runs rough like it is missing or something.
Does anyone know if I might have missed something or did something incorrectly.
Please help this is stressing the hell out of me with now. I retire from the Marines in a month and hell I don't need this problem with the truck.
Thanks in advance to anyone who can help.
Luther
Luther
