Cracked Manifold
Cracked Manifold
Pretty sure my intake manifold is cracked. What is my best option for replacement? I've heard about getting a used one from an 03 truck? Or should I just order an aftermarket replacement?
Truck is an 01 with the 5.4. Thanks in advance.
Just went through this awhile ago....The one on rockauto is a dorman intake and it uses their own rubber o ring gasket type things. It's $191.79, not sure if it comes with o ring gaskets or not. Myself, i wanted to keep it the same as what i took off and went to a junkyard and got one for $200 plus $60 fel pro gaskets, put it all back together and everything is fine..
Just make sure if you get one from a junkyard to triple check both front sides of it where the water crossover mounts to it and make sure its not cracked at all....Thats what cracks and causes a leak...Good luck though.
Yes it is the intake manifold I was asking about. My exhaust manifolds are leaking too and I hope to go LT once the cash comes in.
I have found a used intake off an 03 Expedition for a better price than a new one. Would this work? I remember seeing that the 03 manifolds are little better than others.
