Hesitating real bad
Old May 24, 2011 | 08:48 PM
larbec's Avatar
Hesitating real bad
98 F150 V8 4.6 has been hesitating really bad for about two months now. I have added Techron to it and it seemed to be a little better and the guy at the auto parts store told me to try some Lucas. Well I did and I can not say it was the Lucas that made it worse??? I have been using gas with Techron and had to gas up at a non ethanol place while on my trip
On my way back home from a 120 mile trip my check engine light started to flash on and off for about 45 minutes. It would flash 14 times and then go off. On again for 26 and so on and then quit for the last 10 minutes home. My check engine light is solid now and has been on for over a year. I was told it was the sensor for the EGR and I did not need to replace it??
What can be wrong?
Old May 24, 2011 | 09:42 PM
Toyz's Avatar
Post the actually DTC ex: P030X
And why drive around for a year with a check engine light? Man....
Old May 24, 2011 | 09:56 PM
jbrew's Avatar
Yea , don't waste your time Toyz lol.
I like that, "What can be wrong" ??
Old May 25, 2011 | 08:23 AM
larbec's Avatar
Because the guy at the Ford shop said it was just my EGR valve and no biggie getting it replaced
Old May 25, 2011 | 08:34 AM
jbrew's Avatar
He wouldn't say that and have you keep driving it that way.
A year with a CEL ?
Old May 25, 2011 | 08:42 AM
jbrew's Avatar
It's okay to drive around on 7 cylinders , just ignore it.
That was easy.
Old May 25, 2011 | 08:45 AM
larbec's Avatar
I dint need smart *** answers. I came here for education and help .... Man
Old May 25, 2011 | 08:52 AM
jbrew's Avatar
Are you sure ?
Old May 25, 2011 | 08:57 AM
larbec's Avatar
Yes I'm sure brew I would appreciate if your not going to help please don't reply
Old May 25, 2011 | 08:59 AM
jbrew's Avatar
Alright, go to Auto Zone, get it scanned for free. Write all DTC numbers down as they come up. Stay right there with the guy as he scans and ask for codes. It's a 4six so your going to have to start with a plug inspection most likely or just change them if it's been awhile. Plugs, wires and possibly coil packs (2).
Also , write the EGR code down. Post cdes here.
Old May 25, 2011 | 09:11 AM
larbec's Avatar
Thank you brew. I had a complete tune up including wires, plugs etc back in 2009 and have around 12,000 miles on since then. I will head to AZ in a few
Old May 25, 2011 | 09:23 AM
jbrew's Avatar
You remember what plugs you used ? Probably a coil or the wires, but it could be the egr system as well. Depends on the codes.
Old May 25, 2011 | 09:27 AM
jbrew's Avatar
You can do like this guy did and pull the green line off the valve and plug it. To determine a EVR fault as well. -
https://www.f150online.com/forums/v8...-egr-flow.html
Old May 25, 2011 | 09:47 AM
larbec's Avatar
The codes are a 303 and 401
Old May 25, 2011 | 09:59 AM
jbrew's Avatar
Check the plug chamber for debris, coolant, oil or water. Blow it out w/compressed air to determine this isn't the cause.
303 is cylinder #3, passenger side.
_____________________
Suck test the EGR with a separate piece/section of hose. While the engine is running, suck on the hose like your drinking a milkshake. If the engine almost stalls, then the valve is still operational and your EGR plenum ports aren't totally plugged yet (which is a 4six common problem/ the plenum ports 2). If the engine has no reaction, then the ports are plugged or the EGR diaphragm is blown.
