Engine Stalled and Died
Old May 10, 2011 | 05:54 PM
vtjenkins's Avatar
Hey guys, I need some help...
I just installed the DWV/Gotts intake mod using the rubber downspout coupler on my 2008 5.4L Screw with on only 18,500 miles.
On the way home from work today, about 100 yds from my driveway, my truck started to sputter so I pulled over and the engine died. I started it again and it kept sputtering and died again. On the the 4th or 5th start I took off and after 30-40 ft the engine began to run fine again. Now my check engine light is on and I get a LOW OIL PRESSURE message in the mileage/outside temp screen. My oil guage on the dash is reading normal...
What could be the problem?
Thanks in advance...
Old May 10, 2011 | 06:14 PM
Any codes?
CEL?
With that low of miles its hard to believe it might be a dirty tb or fuel pump driver control module....fuel filters are supposed to be changed every 15k miles.....could be bad gas...try cleaning the maf...
Old May 10, 2011 | 07:53 PM
vtjenkins's Avatar
fuel filter and maf sensor were changed/cleaned last weekend as well... might have been the gas but i've been running the same gas for a half a tank now...
gonna take it to the dealership to see what code the check engine shows...
Old May 10, 2011 | 07:56 PM
Don't pay the dealer - Autozone reads codes free.
Old May 10, 2011 | 08:59 PM
vtjenkins's Avatar
10-4 thanks...
Old May 11, 2011 | 11:19 AM
vtjenkins's Avatar
Checked Code @ Advanced Auto
Advanced Auto checked the code and it was a P0191 - Fuel Rail Pressure. I had them erase it and I guess I'll drive it around and see if it happens again. I changed my fuel filter last Friday and followed the directions provided in the How To section on this site exactly. Would bad gas cause this?
Thanks again...
Old May 11, 2011 | 11:41 AM
I'd take a good look at the FPDM, it may be starting to corrode.
Old May 11, 2011 | 12:41 PM
vtjenkins's Avatar
is that the fuel pump driver module? where is it located?
thanks again for the help, i really appreciate it...
Old May 11, 2011 | 01:21 PM
Under the truck on the drivers side on the cross member in front of the spare tire.....to look at it thoroughly you'll need to drop the spare tire...
Check this link out>>>https://www.f150online.com/forums/ar...highlight=fpdm
Old May 11, 2011 | 09:05 PM
vtjenkins's Avatar
checked the FPDM and it was fine, little to no corrosion. thanks again for the help guys, keep the suggestions coming if you have em...
Old May 12, 2011 | 03:05 AM
2008_XL's Avatar
Did you take it off and check the back? Might as well space it off the frame now while you're at it. If not, it will corrode fast due to dissimilar metals and fail on you.
Old May 12, 2011 | 07:12 AM
vtjenkins's Avatar
Yes, I took it completely off and used a wire brush to remove the small amount of corrosion already there. Are the longer bolts still only available with the new FPDM? If so, are there any cheaper fixes or other bolts to use?
Thanks again
Old May 12, 2011 | 11:05 AM
2008_XL's Avatar
Your best bet would be to buy some longer bolts and some spacers at the hardware store. You'd spend no more than a couple dollars. Also, if you really want to feel safe. Sand it down and spray it with some clear coat.
Old May 12, 2011 | 12:23 PM
vtjenkins's Avatar
^^^ Will do. A local fastener store has the M6 x 1.0 x 30mm for $0.14 a piece. I'll get some washers to act as spacers.
Thanks again guys...
