MSD ignition coils
Old Apr 3, 2011 | 11:41 AM
jbrew's Avatar
Also, you really can't compare, it's impossible to, fairly. - We don't have the same amount of users using one particular brand for proper comparisons. What we have is bunch using Global and Uneeks coils, but the rest is sporadic. We've had users post problems with the high dollar products ie - Accel, Granitelli's, Motorcraft, Moto blue's etc.. NO ONE manufacturer has been able to get away from a bad one out of the box.
Oh, check this out, I wonder if they have them w/gold plating lol (?) - http://www.jegs.com/i/JEGS-Performan...40180/10002/-1
Old Apr 3, 2011 | 01:21 PM
MoNdEetZ_2010's Avatar
Thank all of you guys for replying...and man this a really hard decision to make I wish that all the cops from the manufacterers actually worked so no one would have all the problems a lot of you guys have had...I have no clue what to do im willing to pay a big price but than what if they don't work and than I don't want to go so cheap because what if I will have to keep ordering and ordering until I finally get a pack where they all work...tough decision indeed in my opinion
Old Apr 3, 2011 | 01:38 PM
jbrew's Avatar
If I had to pick another, other than what I've used already, it would be MSD's.
MSD's have a good record, - it's just that they're not as common so there isn't much of one. They cost more, but yea, nothing bad has been reported, so far.
Old Apr 3, 2011 | 01:41 PM
Thanks jbrew so which msd's would fit my truck as I asked on the first post on this thread?
Old Apr 3, 2011 | 01:43 PM
Because every website that I go to says neither fit my truck the only one website that says one fits is summitracing.com but that kind of scares me because how is all the other websites going to say they don't fit but just summitracing doesnt
Old Apr 3, 2011 | 01:54 PM
jbrew's Avatar
Well, post some Links lol.
DG 508's fit any and all 2 valve engines.
DG 511's for the 3 valve.
Post a link of what your referring to ,exactly. I mean that's why you didn't get answer IMO.
Last edited by jbrew; Apr 4, 2011 at 08:48 AM. Reason: user needs to fill info in/ top right corner
Old Apr 3, 2011 | 04:33 PM
ok ohere is the link to summit racing
http://www.summitracing.com/search/B.../?keyword=coil
ok and here is the link to amazon which says the MSD 82438 coils dont fit
http://www.amazon.com/MSD-Ignition-8...ar=1&carId=003
and here is the link to amazon saying MSD 82428 coils not fitting
and it is not just amazon that says they dont fit the MSD website itself says they dont fit and everywhere else i go to aswell... I just need some help basically finding which ones fit. My truck is a 04' ford f150 5.4 3 valve engine not the heritage models its the 04'-08' body style
Old Apr 3, 2011 | 05:56 PM
Matts ford's Avatar
when you go to summit for engine parts dont type in the package(lariat in this case) it takes away alot of the correct parts. looks like you need the 82438
http://www.summitracing.com/parts/MSD-82438/
Old Apr 3, 2011 | 09:22 PM
sam1947's Avatar
The best thing to do is to go to Ebay and type in DG-508 and then DG-511 and compare the two coils. The most determining factor is where the top low voltage connector angles out. The 3v DG-511) engines come out almost straight up where the 2v (DG-508) engine comes out at almost a 45 deg angle. The coils are mostly the same otherwise, it's just tough plugging in the 508 where the 511 belongs (wiring harness restrictions). I think "MATS FORD" is correct in the MSD-82438 being the one you need, that is the set my 07 takes
Old Apr 5, 2011 | 02:13 PM
kep5niner's Avatar
Call MSD for the correct application. That's what I did, and I've been happy with their coils on my '05 5.4. I've used MSD products on many vehicles over the years, and been very happy. Reputation counts for something. I'll pay for peace of mind.
Old Apr 5, 2011 | 08:43 PM
sam1947's Avatar
Ok...I have a dirty little secret, but I'll share for the OP. Three days ago I replaced my plugs with the champions and a set of MSD # 82438. Mind you I'm one of the ones with bad luck with the E-3's. Also for the last 10,000 mi give or take, I have had a very low grade misfire at times even with the motorcraft SP-515 (this truck only has 34,000 mi on it). now, it's only been a few days and very few miles, but I can say, as of right now anyway. The Champion plugs and the MSD coils has made a 100% improvement. No more 'roughness' at any RPM. And ,yes the MAF has been cleaned and the Filter was changed, but the plug/cop change has changed this 5.4 completely (so far). So..for the OP...GO For It !!!
Old Apr 5, 2011 | 10:51 PM
61 falcon's Avatar
my experience, aftermarket coils never last as long as the ford coils. im sure someone may chime in and tell me im wrong. im basing this from real world experience that i have seen come through my bays.
Old Apr 5, 2011 | 11:27 PM
sam1947's Avatar
Maby it's possible that I had one or two 'weak' coils from the start..don't know. I have had a set of uneeks and weapon-x in there, only these MSD's have made a difference..and NEVER any CEL. you may be right on the longevity with these..time will tell..thanks for the feedback 61
Old Apr 6, 2011 | 10:17 AM
jbrew's Avatar
In my experience, cheap aftermarket ebay coils (COP Systems Specific) last longer than dealership Motorcraft coils. I have a milk crate full of flakey Motorcraft coils, - yellow labels, green labels and white stampeded factory coils... I've worked on Fords for 35 years, owned and built quite a few. I've been a member here for awhile, contributed a ton of information and soaked up quite a bit along the way. I've worked on and fixed vehicles a few dealerships fell short on lol. I haven't had one Ebay coil go bad yet. I've been using them for myself and others since 2005.
Old Apr 6, 2011 | 10:44 AM
jethat's Avatar
For the price they absolutely cannot be beat. I've used them in my work van and so far no failures. I bought the more expensive Motoblues for my truck and so far 2 have failed.
