Fuel rail and injector
Old Jan 10, 2011 | 04:32 PM
nenee41's Avatar
I'm showing lean codes 171 and 174 lean on both sides . After much resaerch here it is that little elbow at the back of the intake. Can't get my arm down there . So next step is remove the fuel rail .. Once I take those 4 bolts out do I just pull on it until all injectors and fuel rail come up ... The injecters seem to have a funny little clip on them ... Help please!
Old Jan 10, 2011 | 05:29 PM
Toyz's Avatar
If your going to remove the fuel rail, you should depressurize the fuel rail if it hasnt been sitting long. There is a relief on the rail. I would recommend you zip tying the injectors to the rail before you lift up, so the injectors stay with the rail, otherwise if the injectors stay in their seats and you lift the rail, be ready for fuel to go all over the place. Once they are zip tied, you kind of have to wiggle and lift on each injector. Make sure you have a clean working area around the injectors or debris will fall where the injectors seat.
Year and engine would help
Old Jan 10, 2011 | 05:42 PM
nenee41's Avatar
04 f150 fx4 5.4 ... Do i need a special tool to disconect the line on thedrivers side of the fuel rail
Old Jan 10, 2011 | 05:47 PM
Toyz's Avatar
Somebody else will have to chime in, not familiar with the 04 rails sorry. I was referring to 97-03
Old Jan 10, 2011 | 05:53 PM
nenee41's Avatar
Thanks anyhow , it's crazy this little hose , there's gotta be an easier way
