Are you Still Plauged by the PO171-Po174 codes?
Here's something I came across lately after pulling out my hair
for months on these two codes.
Monitor the cylinder head temperature.
At 186 degrees coolant operating temperature on my 4.6,
My cylinder head temperature reading was at 308 degrees F.
At 265 Degrees, these engines go into fail safe mode and start cutting injectors - Leaning Mixtures, ETC.
This is commonly OVERLOOKED.
Changing the Cylinder Head Temperature switch FINALLY solved my lean codes Problem.
I have also heard of other trucks with a similar problem and they had to have the PCM - Reflashed
because of the computer going screwy and losing it's settings.
on
Your "lean" codes were likely generated before the PCM entered fail-safe.
If you'd pulled your freeze-frame data, the CHT/ECT PID would have provided valuable data that would have guided the diagnosis more quickly.
