fuel filter location
Old Jan 1, 2011 | 01:46 PM
2008 FX2's Avatar
Hi, I am new to the forum, i was thinking about changing my fuel filter and i was wondering where the location of the filter is?
Old Jan 1, 2011 | 01:49 PM
Inside of the frame right under the driver. There are some good instructions on changing the filter in the Articles and How To section. Check the index.
Old Jan 1, 2011 | 01:58 PM
2008 FX2's Avatar
thanks for the help.
Old Jan 1, 2011 | 03:25 PM
2008 FX2's Avatar
fuel filter changed with 35900 miles after two trips to advance, i can't believe all the junk that came out of the filter, i will be changing it every 6 months from now on.
Old Jan 1, 2011 | 03:29 PM
Toyz's Avatar
I do mine once a year. Guess it depends where you get your gas on how dirty it is.
Welcome to the Forums, lots of good stuff around here
Old Jan 1, 2011 | 03:31 PM
I change mine every 20,000 which is about once a year.
Old Jan 1, 2011 | 03:37 PM
2008 FX2's Avatar
i was really amazed at all the junk in the filter, it looked like little chunks of rust, changing my plugs next weekend if the weather permits.
maybe i will be able to get above 15 mpg now? i was getting around 18-19 on the highway till i hit 30000 miles then it went to 15 no matter where i drove or how i drove.
Old Jan 1, 2011 | 03:46 PM
Could be that where you buy gas started using the 10% ethanol blend. You will lose close to 10% with ethanol. Also, could you have changed tire size?
Old Jan 1, 2011 | 03:57 PM
2008 FX2's Avatar
the gas station has always had the 10% blend where i buy it, tires are stock 20's
Old Jan 1, 2011 | 03:59 PM
2008 FX2's Avatar
the truck is basically stock except for the k&n cold air intake and the roll n lock bed cover
Old Jan 1, 2011 | 05:30 PM
Toyz's Avatar
That ethanol can act as a solvent, breaking loose nasties in the tank at the least. I've had issues with what I think was water in the gas lately. From what I have read, ethanol attracts water unlike regular gasses that repel it.
Old Jan 1, 2011 | 11:08 PM
Your K&N oil may have fouled the MAF sensor - clean it.
Personally, I'd put the stock intake back on and do a DWV/Gotts mod to it - and use a dry paper filter.
Old Jan 1, 2011 | 11:20 PM
2008 FX2's Avatar
excuse my ignorance but what is a DWV/Gotts mod?
Old Jan 2, 2011 | 08:42 AM
MotoMike's Avatar
Since no one has mentioned it yet in this thread......be sure to get/use the fuel line disconnect tool and follow instructions in the "how to" thread to change your filter. Its simple once you get the hang of it, but you can damage your fuel line if you aren't careful to use correct tool and follow instructions.
Old Jan 2, 2011 | 10:54 AM
puddle jumper's Avatar
i changed my fuel filter when i done my plugs and it was pretty nasty.i broke the clip on the fuel line so be careful with that
