98 4.6 ???
Old Dec 22, 2010 | 03:21 PM
98 4.6 ???
I just purchased a 96 Lincoln with the 4.6 in it. Im about to change the oil in it and the oil cap says 5w30. Should i run this or did ford change the oil recomendations later on to 5w20? Thanks guy
edit I meant 96 for the title not 98.
Old Dec 22, 2010 | 03:29 PM
novsun88's Avatar
Either or. The older motors used a little bit different weight. to my knowledge ford switched to a different weight oil for more mpgs...
Old Dec 22, 2010 | 04:24 PM
DYNOTECH's Avatar
Yep
Old Dec 22, 2010 | 08:37 PM
I believe the back spec goes back to 96 and earlier - you can use either. My son in law is using 5W30 in his 98 F-150 4.6 because it burns some oil, it has 170k on it.
Old Dec 22, 2010 | 11:22 PM
Thanks guys i just went with the MC 5w30..
