Finding light miss
Finding light miss
I am having a problem that I first thought could be transmission until I read this post... My second thought was a misfire.
My miss is right around 45mph, right after the shift into OD. it's very very light and hard to pick out sometimes. Of course no CEL is on, since it seams like half the motor would need to dislodge itself before it would come on. My question is how exactly do you pinpoint a light miss like I'm describing. The plugs are brand new less then 1000 miles. They are motorcrafts. The wires have about 15k miles on them.. They were with my 4.6, the coil packs are original and have 139k on them. It's a slight possibility that when I was doing my swap I mixed up the packs with the ones that came with my 5.4. The guy I bought the motor from was going to put it in a mustang so my 5.4 came with a couple extra coil packs on the mount brackets. So I picked the two brackets that would work the best. Short of changing out the coil packs and wires what is the best way to troubleshoot this?
To avoid any confusion
Motor is a 5.4 out of an 01
Truck is a 98 that had a 4.6 so it has coil packs not COPs
Doesn't make sense ?? Well, -never heard of one miss this way. You don't have a "dead" miss. Your CEL would blink if your did. It won't stay on, but it will blink at-least 7 times then shut off once the monitor count exceeds parameters.
So, -driven normally, pinpoint "where" in the RPM's your low grade misfire is occurring. They usually occur @ 45 mph and right after the shift into OD. Not always, but it's helps knowing so we can help you.
Not without a Blinking CEL. You can scan it, you might get lucky (I have). You can push the engine right at the miss point to force a CEL (Done that as well). The CEL doesn't stay on, - you know that right?
