will not crank-need help
Old Nov 11, 2010 | 12:55 PM
Satellite Ray's Avatar
1997 F150 V8 with 200,000plus miles, was running ok just stalled.
starter checked at advanced auto parts, works, battery good, flywheel will not move manually. all lights radio meters work.
I think the engine froze
please give me help on what you think may be wrong,
Ray
Old Nov 11, 2010 | 12:58 PM
Remove the spark plugs. If it then turns over, it's hydrolocked. If not, the engine is frozen.
Old Nov 11, 2010 | 01:02 PM
what is hydrolocked?
GLC
What is hydrolocked?
What suggestions do you have
Old Nov 11, 2010 | 01:04 PM
i did remove the spark plugs and it didnt start
if frozen, whqat do you think it will cost to fix? I can do some of the work, if I can get parts
Old Nov 11, 2010 | 02:43 PM
Will it turn over? If not, can you turn the flywheel or crank pulley by hand (or wrench) with the plugs out?
Hydrolock is when you get coolant or a ton of raw gas into the cylinders. It doesn't compress like air. A hydrolocked engine should turn over with the plugs out unless it did something bad like bend or break a rod.
Old Nov 11, 2010 | 03:39 PM
cant turn flywheel
i appreciate the help
i cant turn flywheel at all, I suspect the oil got low
do i need to rebuild the engine?
about how much does it cost?
Old Nov 12, 2010 | 12:58 AM
A lot more than a good used engine from a junkyard.
Old Nov 12, 2010 | 01:07 PM
jbrew's Avatar
Find someone who will install a good used engine for you. That's probably your only option. Your cheapest one anyway...
Old Nov 12, 2010 | 01:14 PM
jbrew's Avatar
BTW- You pull the plugs and turn the crank. Pull the serp belt and get on the damper pulley on the engine, across from the lower part of the radiator. If you can't turn it w/breaker bar, - she's spent.
