99 F150 barly runs
Old 10-17-2010, 01:18 AM
B2_driver's Avatar
99 F150 barly runs
I recently rebuilt the 4.6 in my 99 F150. After installing the engine it shakes at idle and has no power. I do not have any dtc's. The engine is not running on cylinders 1,4,6,or 7. I have spark to these cylinders and the injectors are firing. What could cause this problem?
Old 10-17-2010, 02:34 AM
jgger's Avatar
That is a coil pac model, right? re-double check your firing order and plug wires, not to bag on ya but it is a very common mistake. Start from square one.
Just because there is fire at the plug doesn't mean it's there at the right time, it will fire even if it's the wrong cylinder.
just my $0.02
good luck.
Old 10-18-2010, 11:51 AM
B2_driver's Avatar
I have checked the wires several times and they are as they should be. I have been reading on here that these engines run best on Motocraft plugs so I replace the new Autolites with Motocrafts which made no difference. I have replaced the crank and camshaft sensors also and nothing changed. Any other ideas?
Old 10-18-2010, 12:13 PM
Norm's Avatar
Sounds like your timing is off. Did you remove the timing chain and if so is it back on correctly?
Old 10-18-2010, 02:37 PM
jbrew's Avatar
Autolites ? - Yea some engines will tolerate them, some won't. It's a roll of the dice whether they leave you stranded or not; why chance it ?
I went 40 miles with a new set of 103's/104's. By the time I made it back home , I was running on 6 cylinders.
Pulled the plugs and upon inspection, - the plugs heated up so much , they turned colors.
Advise - Install the OEM Motorcraft Plugs
Old 10-18-2010, 04:07 PM
B2_driver's Avatar
Yes I had the timing set out and installed all new gears and chains. I installed the the set the way that Alldata said to. Maybe I did something wrong. Can anyone tell me how the to set up the timing set on this engine? It is the Romeo 4.6 if that makes a difference.
Quick Reply: 99 F150 barly runs
