P0315
Old Sep 8, 2010 | 02:17 PM
P0315
I had my battery unplugged, and my cluster unplugged and now ive got a P0315 came on last night, on my second drive after the cluster was plugged back in. I noticed the truck was running fine, but it felt like the trans was holding the convertor while i was coasting on the highway, causing a light engine braking.
says crankshaft system not learned or something like that. Anything i should be concerned about?
Old Sep 8, 2010 | 02:23 PM
Found this.
https://www.f150online.com/forums/v8...944-p0315.html
http://www.gearchatter.com/viewtopic11737.php
Old Sep 8, 2010 | 02:28 PM
interesting it talks about key being on until draining the battery. I did have the battery unplugged, and turn the key on to remove the key tumbler from the column during my work.
Also related/unrelated:
Just cleaned my K&N saturday
I disconnected the electronics in the column shifter, which is just the OD off switch and light. And it is still disconnected.
Old Sep 8, 2010 | 02:38 PM
Well I sure as heck can't help with the troubleshooting, but I wouldn't think what you've done with the shifter swap and filter cleaning would have an effect towards the code you've pulled.
Old Sep 20, 2011 | 06:22 PM
I got the code after pulling battery again, and now that external link is down. Im trying to remember what i did to relearn it last time.
Something like 70-0 coasting to a stop?
any help here guys?
Old Sep 20, 2011 | 08:32 PM
Stu486's Avatar
i have read 60-40 3 times...here is one that i read.
https://www.f150online.com/forums/1543208-post4.html
Old Sep 20, 2011 | 08:48 PM
thanks for the additional in house link i will try it tomorrow.
Truck drives great, just the engine is being held onto by the trans on decel, like a soft engine braking from 70-50 and then lets go and coasts normally from 49 and slower.
Old Sep 24, 2011 | 12:22 AM
Any luck Pat?
Old Sep 24, 2011 | 09:55 PM
took two or three tries of the light coming back but i think i finally got it.
Not sure if it has to simultaneously relearn the Jmod, and other mods as well which makes it harder for the PCM.
I drove about 20 miles today total, with two highway cruises (with coasting decel), and no light yet
Old Sep 24, 2011 | 11:44 PM
Glad to hear, keep us updated
