help truck wont start
Old Sep 5, 2010 | 06:33 PM
04F150XLT's Avatar
i got in my truck this morning and went to start it nothin happened except for a clicking coming from the fuse box so i figured out which relay it is and replaced it still nothing. and the clicking was still there I tried charging the battery nothing happened so i tried jumping it still nothing i dont know wat to do someone help
Old Sep 5, 2010 | 07:05 PM
enriched's Avatar
might be bad battery cables and or connection
might be bad battery or starter
do your head lights and radio turn and play?
are you in park fully(if automatic tranny) ...& ...in neutral and clutch depressed fully (if manual tranny)..if yes to these then safety neutral switch could be bad
Old Sep 5, 2010 | 07:19 PM
jethat's Avatar
Check connections first all of them including the one on the starter that one corrodes especially in snow areas where lots of salt is used on the road. ford starters rarely fail so that would be the last thing. if the connections are good try jumping the truck if that doesn't work short the big post to the small post on the fire wall relay if it starts replace the relay.. If you jump it and it starts test the battery..
Old Sep 5, 2010 | 07:23 PM
04F150XLT's Avatar
everything turns on radio lights etc.... truck is in park fully
i tryed jumpin it with my buddys truck didnt do anything the clicking from the relay is coming from the accesory delay relay
and were can i find the firewall relay
Old Sep 5, 2010 | 07:27 PM
rglass62's Avatar
Take your battery connecters off and clean them as well as the battery posts. If that doesnt work turn your key to run position take a screwdriver and and jump between the two posts on your starter relay on your firewall if it starts you have found the problem. If not check all your grounds and positive cables all the way to the starter and grounds to the frame. Im sure this is a simple fix good luck!
Old Sep 5, 2010 | 07:45 PM
04F150XLT's Avatar
the only relay box under the hood is on the driver side fender
Old Sep 5, 2010 | 07:49 PM
rglass62's Avatar
Your starter relay is on the passinger side firewall follow the wires from your battery and alt and it will lead you straight to your starter relay.
Old Sep 5, 2010 | 07:51 PM
04F150XLT's Avatar
alright ill go out and try it
Old Sep 5, 2010 | 07:58 PM
04F150XLT's Avatar
i took the starter solenoid relay out but im still not sure what do from here
Old Sep 5, 2010 | 08:01 PM
Don't take it out. Didn't you comprehend this?
Old Sep 5, 2010 | 08:03 PM
04F150XLT's Avatar
i dont know wat big post and what little post
Old Sep 5, 2010 | 08:06 PM
Get a new battery.
jethat's Avatar
Call a friend who can work on cars. If you dont have one call a wrecker and take it to a shop.
Old Sep 5, 2010 | 08:09 PM
04F150XLT's Avatar
i can work on cars if someone would just tell me wat big post and what little post then i could get it
Old Sep 5, 2010 | 08:16 PM
rglass62's Avatar
just short between the two posts with a screwdriver it will spark alittle if it starts replace the relay you can do it its not that hard lol!!!!! ps. its the only large boits that have wires going to them.
