Spark plugs?
I just hit 100k in my truck and I'm trying to figure out what's the best choice for new spark plugs in my 4.6 2v. I have no idea what to use. What have you guys used for spark plugs when you changed them?
2. Denso Iridium IT-16's.
3. If running boost: IT-20's
MGD
PS - before glc jumps in - 28ft-lbs, DRY ( no anti-seize)
i have an 05 skrew with the 5.4 . i jus changed 1 of mine thak had fouled out . that is the last plug that will go into the truck as long as i oen it. worst thing i have ever attempted on an engine.. hope u have better luck. and if yours have the same type of plug as mine do your research and ask a ford tech and follow there advice exactly as they tell u .. there r tricks to remove them........ safe cracking is easier..lol
To the OP: You put 100,000 on a set of plugs and want to know what plug to use? Use the same one you take out! Motorcraft. How could one be any better?
Attention - OP!
Don't use the same one ya took out!
Use a NEW one just like it!
MGD
Glad I could fill in
MGD
, sooo..motorcraft is the best choice?
