Truck won't start
Old May 7, 2010 | 12:49 PM
fritz4077's Avatar
Truck won't start
ok heres my problem...i turn the key and the motor turns just wont fire...got 40 psi of fuel pressure and the pump turns on..and this is on a 01 L motor that i swapped in my truck... could it be plugs cause i just put some new ones in it i pulled on out and it was a little black and smelling like fuel...any thoughts
Old May 7, 2010 | 02:09 PM
Toyz's Avatar
Doesnt fire at all? And you just put new plugs in... doubt its plugs. Might want to check your coils for spark. If the plugs are new and you have 40psi at the rail, I would say theyre not firing. Especially if you pulled them and they smell like gas.
Im not sure what it would be, fuse.. relay or something, duno. But I would say check for spark at any coil cause I doubt there is any.
Old May 7, 2010 | 02:13 PM
fritz4077's Avatar
ok thanks man...do i check every coil first off...and when i do it do i pull off the coil and hold a screwdriver close to it or something while someone cranks the truck and if it sparks
Old May 8, 2010 | 06:51 AM
Veteran: Army
did you have the ECM reprogrammed to communicate with the cluster or did you use the lightning cluster???
you are using the lightning ECM and 4r100 trans correct???
Old May 8, 2010 | 12:31 PM
fritz4077's Avatar
i have the lightning pcm...main harness..4r100 harness..and engine harness..
Old May 8, 2010 | 12:56 PM
Labnerd's Avatar
Take a battery jumper cable from the HEAD to the negative side of the battery and see if it starts. If so, you have a bad ground.
Old May 8, 2010 | 02:35 PM
fritz4077's Avatar
but the starter spins and everything...all the electronic features work
Old May 8, 2010 | 11:58 PM
Labnerd's Avatar
You said you put this engine in the truck so obviously it is not the original. If it was rebuilt or the heads were removed at anytime, if the person putting the heads on used any kind of sealant on the head gasket or some even put sealant on the head bolts, you have just insulated the head from any ground and the head will have to have it's own ground or the plugs will not fire or will weak fire. The head is grounded thru the head bolts which must stay clean. Kapech?
Old May 9, 2010 | 11:17 PM
fritz4077's Avatar
i dont think the heads where ever removed or nothing
Old May 10, 2010 | 12:54 AM
Toyz's Avatar
Keep double checking your work. Might have missed something at the solenoid? Not sure but go over it all, check for motor to chassis ground straps. Theres a few that run from the block to the front intake plenum, right around the thermostat housing on your year I think.
Old May 10, 2010 | 05:25 AM
jbrew's Avatar
Bleed the rail again, then try. Mine did the same thing when swapping injectors. Or wait a day or so, then start.
Old May 10, 2010 | 11:30 AM
fritz4077's Avatar
ok thanks guys i will do everything today and tell you whats going on later
