Lightning Engine help needed !
20Screw01,
Your code P0175 involves the driver side, bank 2. This code has to be addressed before any other diagnostics is performed. What have you done to eliminate this code? When you replaced the injectors did you also replace the driver side injectors?
I did not replace the drivers side injectors yet due to seeing the fouled plugs on the PS bank. I was wondering why it would say its a code from the ds bank when the ps is so rich?
Also if anyone wants to take a look at the datalogs from the ds and ps bank please send me a message...Thanks!
Do you guys think that I should replace the injectors on the bank with the code? Even though the plugs look good on that bank and the other bank (PS) are wet and fouled?
Thanks Dave..
Thanks Dave..
I am going to replace the other four this weekend so that will be all of them. The thing I cant figure out is why the rich code is coming from the DS bank but the plugs look great. Then the PS Bank plugs look horrible and soaked but no code for that bank?
Thanks Dave..
Thanks Dave..
Ok I have already cleared the codes and I will disconnect the battery for 10 min to reset correct? I have no idea what to do about the fuel pressure at idle? Is that in the tune that it can be adjusted or is there something I can do?
Further Klitch asked; is the fuel system stock? Did you add a higher flow pump to the tank / fuel line or are you using some other way to increase fuel delivery?
Nope I have no controler. I just threw a 255lph in it and thats it. Stock fuel system except for that. And then bolted the lightning motor in. I am now assuming I need a controller? Klitch do you have one for your swap?
