'06 5.4...Weird tube underneath...
Old Mar 3, 2010 | 06:13 PM
batmeat's Avatar
So I'm sorry if this is in the wrong forum, but I don't know what this tube is that looks like it spans the length of the truck and ends in the engine bay. It's kinda dark right now, I'll get a picture of it tomorrow. It looks like a thick piece of black rubber tubing hanging down just behind the engine bay. The end has a clamp to make an eye. The best way to describe it is to picture a sewing needle, except black and flexible. That eye loop is what is dragging on the ground. Any ideas?
http://img534.imageshack.us/img534/2978/dscn1620p.jpg
http://img641.imageshack.us/img641/4346/dscn1621v.jpg
There's the images. It looks like some sort of drain.
Old Mar 3, 2010 | 06:19 PM
azmidget91's Avatar
emergency brake cable
Old Mar 3, 2010 | 06:21 PM
batmeat's Avatar
I don't think that's it. E-brake works ok, unless it's just a shell for it.
Old Mar 3, 2010 | 06:29 PM
azmidget91's Avatar
is it the drivers side or passenger side
Old Mar 3, 2010 | 06:36 PM
batmeat's Avatar
slightly closer to the drivers side.
Old Mar 4, 2010 | 08:48 AM
batmeat's Avatar
Loaded the pictures. It looks like a drain of sorts, but I can't figure out what the loop was connected to so it wouldn't dangle.
Old Mar 4, 2010 | 09:41 AM
sfam198's Avatar
is that second pic looking toward the front or back of the truck? if toward the back, it looks like it's coming from the transfer case. could be a vent tube. not sure why they felt the need to make it that long?
Old Mar 4, 2010 | 10:26 AM
JMC's Avatar
JMC
25 Year Member
That is the breather for the transfer case. It needs to be attached to the firewall. The loop is there to keep liquid from entering the tube. If you let it hang you risk getting water in the transfer case.
Old Mar 4, 2010 | 10:46 AM
Harper 184's Avatar
^^^ yes def. a T-case vent like JMC said.
Old Mar 4, 2010 | 01:13 PM
batmeat's Avatar
alrighty. Now I gota see what it hooks to at the firewall. I didn't see anything when I took the pictures. Anyone able to take a picture of theirs? BTW, thanks for the help. Yes, that second picture is facing the rear of the truck. You can see the drive shaft and the exhaust on the right side.
