Low oil preassure at first start up
Old Feb 11, 2010 | 04:26 PM
njmike's Avatar
I have a 2001 f150 with the 4.6. When its really cold out and my truck has been sitting a while the oil preasure gague doesent move until it wamrs up a little bit the it goes to the normal position in the middle. It doesent run any different when the oil preassure gague reads no preasure, does anyone know what my problem could be.
Old Feb 11, 2010 | 05:01 PM
Norm's Avatar
The 01s (and other years) suffered from sensors that stuck when cold. I would replace the sensor. I had to do mine. Once it warms up it works fine. There is a TSB that explains this.
Old Feb 11, 2010 | 07:36 PM
njmike's Avatar
Thanks norm i was hoping it was just a sensor or something was it hard to replace the oil preasure sensor, how much are they.
Old Feb 11, 2010 | 07:45 PM
This thread tells you where it is, and even has a picture.
https://www.f150online.com/forums/v8...-dropping.html
Depending on which one you have, it's between 10 and 30 bucks.
Old Feb 11, 2010 | 08:00 PM
whackemnstackem's Avatar
it could be that your "sensor" is sticking and needs replacing but first off you have to understand that its not a sensor at all, its a switch. and your guage in your truck aint reading sheeit. take a look at this thread... https://www.f150online.com/forums/v8...iot-gauge.html
Old Feb 12, 2010 | 06:11 AM
shifty_85's Avatar
also on frist start ive notice on my aftermarket gauge it takes a few seconds to get oil press. do to the oil being thick and hard to move when its cold. but when i do get press. its 70-80PSI lol
Old Feb 15, 2010 | 04:50 PM
njmike's Avatar
Thanks alot everybody im guessing thats my problem. After everything i read about that stupid gague ford should of just left it off and put the idoit light in. im gonna go to ford tomorrow and get the part and see if it works.
