Hard To Find Leak?>???
Hello I have leak that i can't find?? I own a 1998 Ford F150 4ngine is a 4.6 V8 W in VIN. i noticed a leak around the back of engine and up toward the transmission it looks like the transmission leaks radiator?? I have no Heat and no water in engine or tranny?? any Ideas?? How hard is to rebuild this engine>>?? I am going to try to tackle this problem in a week or too?? and where can i get blown up pictures of the engine and body??? Thanks all have a great day!!
I meant no heat in cab and not over heating, no water in transmission fluid and no water in oil. I looked yesterday and i believe it might be the rear main seal. I can' spot any leaks on the back of engine, but it coming from where the back of engine meets and tranny meets leaking from flyweel? Looked for hoses and hoses are fine?? ill take some pics if i get a can?
Mine was leaking like crazy there, ended up being the O-rings behind the water pump for the heater core tube connect. Valley fills with coolant, then leaches thru an , -what looks like an inspection plate and drains right on top of the starter/ puddles on the ground.
It was difficult to find, take a flashlight, look in the valley/ top of the block/ behind the alternator.
Is it wet ? Standing Coolant ? There you go.
But yea, definitely could be a head gasket as well. Check everything posted, good posts!
Sorry
I have been busy with Uncle Sam so have not been bale to reply to threads! I will be pulling the engine on Sat this week and Pulling parts off on fri let yall know what i find out!
