Help
Help
I just purchased a 97 f150 4.6 and it does have a miss fire but the last couple of day i have noticed that form off idle to about 2000 rpm lack of power and throttle response plus a backfire in the engine. Give me an idle. Thanks
You may want to check out cyl #4 in particular. The heater tube that sticks up from the intake manifold at the rightside rear (passenger side) of the intake and connects with one of the heater hoses has a tendency to leak coolant that drips down right into the #4 sparkplug hole. This causes a miss in that cyl. Check the hose clamp and even install a second clamp if possible. Take care.
