look at this junk starting
Old Dec 9, 2009 | 03:43 PM
Camarothatcould's Avatar
http://www.youtube.com/watch?v=tx-GM35felw
Old Dec 9, 2009 | 03:46 PM
theres a 2 second delay after i turn the key forward the first time... I just put a brand new 850CCA battery and alternator on it... Think its the starter that makes it delay? btu why only the first attempt??
Old Dec 9, 2009 | 04:23 PM
Veteran: Army
only an 850cca???
Old Dec 9, 2009 | 04:27 PM
yea, highest one AcDelco had...
Old Dec 10, 2009 | 05:32 PM
JMC's Avatar
JMC
25 Year Member
Assuming all your battery cables are OK either the Relay switch on the firewall or the solenoid on the starter gets lazy over night. Short the switch on the firewall first. The two large terminals get shorted together. If it fires right up I would suspect the switch is defective. FYI the switch is grounded through the case. Corroded mounting bolts will make the ground irregular.
You don't have an aftermarket alarm or a remote start do you?
Old Dec 10, 2009 | 05:40 PM
I shorted the starter solenoid out today, the starter just clicks now, that sit.. its dead... im changing the starter now... on my back, on fresh stitches... haha
Old Dec 10, 2009 | 05:41 PM
nothing aftermarket... i went to turn key today and just a click is all i got... its about 15 degrees outside now...
Old Dec 10, 2009 | 07:37 PM
just put in fresh starter.. perfect.
Old Dec 11, 2009 | 03:39 AM
Old Dec 11, 2009 | 09:30 AM
Chipper's Avatar
You gonna eat that banana? Glad you fixed the problem.
Old Dec 11, 2009 | 11:14 AM
No I got biscuits and gravy
Old Dec 12, 2009 | 06:02 AM
Veteran: Army
he saved the banana for later
Old Dec 12, 2009 | 06:03 AM
Veteran: Army
x2
