Time-Sert or Helicoil?
Hi all. I have an 01 expedition w/5.4 Triton 115k mi.#4 plug blew out on me (passenger side all the way in back of engine of course)stripping the threads in the head.First time this has happened to me.Upon researching I see that this is a common problem (and a costly one to have repaired). I've decided to give a stab at installing an insert myself but I see that there are a couple of different products out there.We have the Helicoil or the Time-Sert. Due to the location on the engine it seems that the Time-Sert is a better choice after watching videos on line. The Helicoil requires a small amount of striking and I don't have the clearance to do that in the rear of the engine.Do I need to remove the cylinder head to do this? Has anybody had any experience with both products? Also are there any good how to videos that anybody can recommend?
I have no idea of the cost. Since you have not been a member long enough to use PMs, you will need to email him to get in contact. Click on this link to one of his posts, then click on his name. You will see there, the option to email him. Good luck.
https://www.f150online.com/forums/3986817-post15.html
Hey dude, I think I just sent you an e-mail...check and let me know. My email address is amsoil@galaxylubricants.com if you don't find it elsewhere!
Do some more searching and reading on here about TimeSert...you be reading until Christmas...'10
I think you will discover that TimeSert is the only way to go. Keep in touch.
Timesert is the best way to go.
I recently used it on my 99' Lincoln Navigator.
real easy to do.
the instructions are straight forward.
heres some more info..
https://www.f150online.com/forums/v8...t-problem.html
real easy to do.
