5.4 Timing
Old Dec 4, 2009 | 08:24 PM
fordguy00's Avatar
5.4 Timing
I was turning my crank to TDC when the crank pully bolt snapped off in the crankshaft. So I continued to tare it down without TDC but i am completely re-doing the motor. i have it down to the bare block and the bare heads. my question is when i am puting it all back together how do i go about finding TDC for the pistons and the heads.
Old Dec 4, 2009 | 08:35 PM
Paralyzer's Avatar
what year? most chains will have links that are darker in color and you line them up with dots on the cam and crank. If you tell me the year i can send a pic.
Old Dec 4, 2009 | 08:59 PM
fordguy00's Avatar
2000 windsor. i guess my main concern is getting the cams right. i am puting new valves cams and pistons. Also any recomendations on which brands and lift and duration to go with? I am going to be doing alot of pulling and 4x4ing. thanks
Old Dec 4, 2009 | 09:09 PM
fordguy00's Avatar
also boring it out and port, polish. Or do they make a stroker kit for the 5.4L?
Old Dec 4, 2009 | 09:15 PM
Paralyzer's Avatar
ok each chain will have 3 links a different color then the others(either black or copper)2 will be side by side and one on its own. here is how to set the cam timing.
id look into ford racing cams myself im not to familiar with aftermarket cams on these trucks, but from what ive heard you dont gain to much from them..... look into Manley for connecting rods and pistons.
http://www.manleyperformance.com/nic..._pistons.shtml
Old Dec 4, 2009 | 09:16 PM
Veteran: Army
hit up paschal performance they offer a 5.8 and a 6.2 kit
Old Dec 4, 2009 | 09:19 PM
Paralyzer's Avatar
if it were me id leave it as a 5.4, build it. and add boost. Who needs a stroker
Old Dec 4, 2009 | 10:25 PM
fordguy00's Avatar
I get the timing part if i were doing a head gasket or something and it was already together, but i'm startin from just a bare block, new crank rods pistons bearings, bare heads new cam valves. How can i find TDC for the valves with a new cam and the head off the block? Or do i basically have to mock everything up to find the timing? Is that where the "safe mode" comes in? For the block when it's together i just put the # 1 piston to the top of the deck? Would the be considered TDC? Sorry for the inconvience i just want to get it all right the first time. thanks
Old Dec 4, 2009 | 10:34 PM
Paralyzer's Avatar
when both the exhaust and intake lobe are on the base circle that will be around TDC, if thats what your asking. But why do you need to know this before assembly? Just line the marks up when you go together and it will be timed.
Old Dec 4, 2009 | 11:07 PM
fordguy00's Avatar
Cuz i can't afford to do it twice. lol. just wanna make sure it's right. thanks alot for the info. and hopefully it won't be to long before i get it all done. thanks again
