Idle problem.. Please help
Old Dec 4, 2009 | 03:15 PM
06LincMarkLT's Avatar
Hey Guys,
I have noticed that my truck has little to no idle... If i let off the brake in drive or reverse on flat ground it wont move. Is this normal? Or is there some way to tune it up a little? Its kind of tough when im trying to back up with no idle, i end up hitting the gas to hard sometimes... (06' 5.4L)
Old Dec 5, 2009 | 02:10 AM
Do you have a tach, and if so, what is the idle rpm in gear? It's probably normal. If you are having coordination problems, drive with 2 feet, modulate the brake with your left foot.
Old Dec 5, 2009 | 04:26 AM
jethat's Avatar
No adjustment on modern engines and it sounds like your truck is running good. Use your right foot..
