08 4.6l misfire
08 4.6l misfire
last night my truck started missing violently at a stop light, it threw a code (cyl 3 misfire). i got it home disconnected the battery and reconnected it this morning, now it idles fine in park and Neutral but once its under load it wont rev out over 4k and takes forever to get there. im pretty sure its the coil pack that went bad but after looking for a replacement all i can find is the autozone ones and im pretty sure this isnt covered under warranty even tho the truck only has 24k miles on it.
any recommendations of a good replacement packs and plugs. it has the stock exhaust and intake still.
Being that the factory recommended plug change interval is 100k and there is no recommended change interval for the COP's, it should definitely be covered under warranty.
If you want to change them yourself anyway, use OEM Motorcraft plugs and DG508 coils from Global Automotive or Uneek Supply on Ebay.
