Block heater removal..
Old Nov 28, 2009 | 12:11 PM
jethat's Avatar
is it possible to get the engine block heater out without ruining it? how would I do that? new engine don't have it and I'd like to put it in it..
http://i70.photobucket.com/albums/i8...g?t=1259428484
Old Nov 28, 2009 | 01:03 PM
Camarothatcould's Avatar
lolz. no.. I tried on my old one... New one is only like $20
Old Nov 28, 2009 | 02:08 PM
jethat's Avatar
where did you get it? thanks..
Old Nov 28, 2009 | 04:57 PM
NAPA... Any parts store should get it... they are very generic parts
Old Nov 28, 2009 | 09:35 PM
jethat's Avatar
I got it from the dealer.. Autozone and Oriellys didnt have or the parts monkeys there couldn't find it. $45 had to get it to get it installed.
Old Nov 28, 2009 | 09:41 PM
Klitch's Avatar
the ones i paid for were about $35-40. its not easy to get it out and reusable. it took me a lot of slow working it back and forth with a screwdriver gently under the lip.
Old Nov 29, 2009 | 02:11 AM
its not worth it to try to pry it out. Its soft and it bends... you pry it it will distort it and it will leak.. get a new one... even better, get a circ type pump!!!!!
Old Nov 29, 2009 | 11:43 AM
jethat's Avatar
I just wanted my truck to have what it had before.. I rarely use it. Just wanted to keep its original stuff. I have the plug that goes in the wiring harness and all. Now it will still function. When I have used it I notice it really dont work all that great.. It wasnt really worth it but I did it..
Old Nov 29, 2009 | 12:30 PM
they make a big difference... its all about warm-up time on gassers... diesels ofcourse need them to even start, but it helps gassers warm up quick, especially with our alum heads n cast block, they heat up differently and thats what blows headgaskets... keepin the block warm helps with heat up so the block n heads stay around the same temp
Old Nov 29, 2009 | 01:39 PM
Steve83's Avatar
I've never tried to remove an old one, and I've never seen one on a modular engine, so are yours different from this diagram, or do they just gum up THAT badly?
Old Nov 29, 2009 | 01:57 PM
they gum up real bad. Several I have removed from powerstrokes and have wired wheeled them up nice and clean.
